Capacitors in Mesa Boogie Dual Rectifier
Postby Ricotjuh » 12 Jan 2019, 23:54
Hey,
In a Dual Rectifier, 1uF capacitors are connected to the cathode. Via an LDR or resistor to GND.
But when I look at the PCB these are not ordinary electrolyte capacitors, but yellow capacitors that look very similar to the construction of a resistor. The + side seems to be a bit tapered. See image below. Picture is not from the DR, but from another Mesa. But it only concerns the type of capacitor.
Someone any idea what type of capacitor this is, and what the advantage is, compared to an electrolyte capacitor.
Ricotjuh
Re: Capacitors in Mesa Boogie Dual Rectifier
Postby temol » 13 Jan 2019, 00:05
Looks like tantalum axial capacitor.
T.
temol
Has thanked: 13 times
Have thanks: 133 times
Postby Ricotjuh » 13 Jan 2019, 00:36
You mean something like this?:
https://goo.gl/images/YqVVNf
Ricotjuh
Postby temol » 13 Jan 2019, 09:39
Exactly. Check this - 1u tantalum axial cap.
T.
temol
Postby Ricotjuh » 13 Jan 2019, 09:45
Completely clear. Thanks for the quick response
Ricotjuh
Postby Optical » 14 Jan 2019, 02:28
Yeah Kemet tantalums
They last for a long time vs electrolydics, dirt cheap, fail obviously and are generally more compact - reasons why Mesa uses them.
They also fail shorted (an obvious giveaway vs a slowly wearing out electro cap) but seem to work well and last for a long time in Mesa amps regardless
Optical
Have thanks: 14 times
Postby Rocket Roll » 15 Jan 2019, 15:29
Actually, they have a higher failure rate than electrolytics, all of the data suggests.
One of the possible reasons for using them is distortion. When placed on signal path, they tend to introduce non-linearities, the sonic signature of which is very much respected in both pro-audio (Rupert Neve) and guitar-based audio (Tube Screamer, Rat).
Rocket Roll
Have thanks: 34 times
Postby Ricotjuh » 07 Jun 2019, 14:00
Now I have the following question. In the power amp section of the amplifier there is a 100nF capacitor (C51) in the feedback loop. But I think this is an MLCC capacitor. Anyone have any idea why no Orange Drop type capacitor is used here like in the rest of the amplifier? This also happens with C52. This is also a 100nF capacitor.
These are the two capacitors at the very top. Just below the resistor of the middle tube.
Ricotjuh
Postby plush » 07 Jun 2019, 21:02
Ricotjuh wrote:Now I have the following question. In the power amp section of the amplifier there is a 100nF capacitor (C51) in the feedback loop. But I think this is an MLCC capacitor.
It can also be XY cap for safety reasons.
Or because the board lacks space.
For this message the author plush has received thanks:
thetragichero (17 Jul 2019, 19:30)
plush
Has thanked: 28 times
Have thanks: 66 times
Postby alexradium » 09 Jun 2019, 07:50
Ricotjuh wrote:Now I have the following question. In the power amp section of the amplifier there is a 100nF capacitor (C51) in the feedback loop. But I think this is an MLCC capacitor. Anyone have any idea why no Orange Drop type capacitor is used here like in the rest of the amplifier? This also happens with C52. This is also a 100nF capacitor.
[ Image ]
[ Image ]
you don't need a HV capacitor there,there is probabli 10/15Vdc on one side.
alexradium
Has thanked: 58 times
Have thanks: 62 times
Postby Ricotjuh » 09 Jun 2019, 09:07
Okay, but what type of capacitor is normally applied at this position?
I assume that Mesa deliberately chose this type ?!
Ricotjuh
Postby GeneralTiger1 » 17 Jul 2019, 04:48
Ricotjuh wrote:Okay, but what type of capacitor is normally applied at this position?
1. Detect small capacitors below 10pF: Because the fixed capacitor capacity below 10pF is too small, use a multimeter to measure, only qualitatively check whether it has leakage, internal short circuit or breakdown. When measuring, you can use the multimeter R × 10k block, use two meter pens to connect the two pins of the capacitor, the resistance should be infinity. If the measured resistance value (the pointer swings to the right) is zero, the capacitor leakage is damaged or internal breakdown. https://www.allicdata.com/list.html?category_id=1431
2. Detect 10PF~001μF fixed capacitor: judge whether it is good or not by judging whether there is charging phenomenon. The multimeter uses R × 1k block. The beta values ​​of the two triodes are all above 100 and the penetration current is small. A composite tube of 3DG6 and other types of silicon triodes can be selected. The red and black test leads of the multimeter are respectively connected to the emitter e and the collector c of the composite tube. Due to the amplification effect of the composite triode, the charging and discharging process of the measured capacitor is amplified, so that the multimeter pointer swing amplitude is increased, thereby facilitating observation.
It should be noted that during the test operation, especially when measuring the capacitance of a small capacity, it is necessary to repeatedly exchange the two points of the measured capacitor pins to contact A and B to clearly see the swing of the multimeter pointer. For fixed capacitors above 001μF, the multimeter's R×10k block can be used to directly test the capacitor for charging process and whether there is internal short circuit or leakage, and the capacity of the capacitor can be estimated according to the amplitude of the pointer swinging to the right.
GeneralTiger1
Postby Optical » 17 Jul 2019, 05:54
Any type of cap can be used here.
Some caps introduce nonlinearities as previously mentioned. Caps of this type generally introduce a gritty texture to the sound.
Mesa will have chosen those particular caps by substituting cap types until they picked their favourite.
Optical
Postby FiveseveN » 17 Jul 2019, 09:43
Optical wrote:Caps of this type generally introduce a gritty texture to the sound.
For this message the author FiveseveN has received thanks:
alexradium (17 Jul 2019, 11:56)
FiveseveN
Has thanked: 133 times
Have thanks: 55 times
Postby plush » 17 Jul 2019, 10:13
Optical wrote:gritty texture to the sound
OH YEAH, YE OLDE GRITTY CAPACITOROO.
They really don't.
plush
Postby Optical » 18 Jul 2019, 05:35
I guess you've never built a high gain tube amp then
Lower classes of ceramic caps exhibit hysteresis and will change value with frequency - especially when run close to their voltage ratings, but you can’t control what they change to. In high gain amps it is pretty common for the builder to trial a few capacitor types and select whichever is their favourite for the given circuit.
It's most common to use low class ceramic type in treble peakers, bright caps, as treble filter caps and tube power amp feedback circuits to exploit certain tones as that's where the effect is most apparent.
Dont take my word for it, go swap caps to some low class ceramics vs foil and whatever else in those places in a high gain preamp and see for yourself.
And here's some evidence for you two, since you think this is some kinda witchcraft :p http://diyaudioprojects.com/mirror/memb ... /caps.html
Notice what the ceramics are doing?
For this message the author Optical has received thanks:
bajaman (18 Jul 2019, 12:06)
Optical
Postby bmxguitarsbmx » 22 Jul 2019, 06:54
+1 Optical. Skepticism is High with the Stompbox community about component type, circuitboard layout, ground planes, etc. In an effort to not buy into "Magic" they overcompensate by being well.... let's just say,"skeptical". Just remember: You can approach things as a Skeptic, or you can approach things as a Scientist. The two are not the same. A Skeptic actually gets a dopamine boost from posting things like "got evidence?". Which is essentially how you develop a bias that would pollute your scientific experiment.
For this message the author bmxguitarsbmx has received thanks: 2
J0K3RX (02 Aug 2019, 17:01), Optical (22 Jul 2019, 22:36)
bmxguitarsbmx
Has thanked: 280 times
Have thanks: 86 times
Postby FiveseveN » 22 Jul 2019, 19:34
Optical wrote:but you can’t control what they change to
And yet somehow you can generalize to "caps of this type sound like this" without taking into account what their purpose in the circuit is, how much voltage is across them and for how long, and maybe most critically, how much more the signal gets mangled downstream. Are you telling me you can detect the distortion from the input cap in a high-gain amp, that 0.01% before the following 300% THD is introduced? What about the other way around? Have you actually, properly tested this (double blind A/B) or just trusting someone's account/opinion?
And WTF does "gritty texture" even mean? Oh, it's distorting?! Fuck me, I thought Rectos were supposed to sound squeaky clean!
Yes, we know dielectrics are not perfect, and some are less perfect than others. Show me how you get from that to "caps of type X sound like Z". Show me your "scientific experiment".
FiveseveN
Postby Optical » 22 Jul 2019, 22:34
Gritty sound is a crap description I agree. I'm not saying caps of X type sound like whatever.
My only point is that nonlinearlities elicited from certain capacitor types have an audible and measurable effect on the harmonics generated in a high gain preamp; and that builder/designers will trial some of those cap types before making a decision on what to go with. If you dispute this despite the above evidence and observations shared by high gain amp builders, then i dont know what to say to you...
Optical
Postby FiveseveN » 23 Jul 2019, 09:27
Optical wrote:I'm not saying caps of X type sound like whatever.
There must be something wrong with my reading comprehension then. I'm not a native speaker after all.
Nine years since The Cap Thread started, the best evidence of this "audible and measurable effect" are these two tiny bumps, which were even less significant in my measurements (same source, different FFT). If you've missed it, you'll find plenty of opinions in that thread. Some of the posters have even built high-gain amps, including me. Just please don't pretend that there's something wrong with valuing evidence over opinion.
J0K3RX (02 Aug 2019, 17:03)
FiveseveN
Next
Return to Amplifiers
