Tube Amp Links
Re: Tube Amp Links
Postby stevo58 » 03 Dec 2008, 22:09
You can't talk about amps without Doug Hofmann's forum and his library pages: http://www.el34world.com/Forum/index.php
not to mention parts
steven
stevo58
Re: Tube Amp Links
Postby Nikifena » 07 Dec 2008, 08:53
Verry usefull tube tech site !
http://www.freewebs.com/valvewizard/index.html
I found it right now.
Nikifena
Have thanks: 34 times
Re: Tube Amp Links
Postby juse » 08 Mar 2009, 08:10
Adam's Amps: http://amps.zugster.net/articles/tone-stacks
Blue Guitar: http://blueguitar.org/schems.htm
4X12 Cab Recover Tut: http://www.thegearpage.net/board/showth ... x+tutorial
Harmonic Appliances: http://www.harmonicappliances.com/
Vintage Amps Forum: http://vintageamps.com/plexiboard/
Automotive ignition coil transformer (use at your own risk): http://www.allaboutcircuits.com/vol_6/chpt_5/19.html
Vacuum Tubes (Radio Electric Supply) - World's Largest Supplier of Tubes: http://www.vacuumtubes.net
juse
Have thanks: 5 times
Re: Tube Amp Links
Postby JiM » 08 Mar 2009, 14:46
A nice list of schematics, especially Marshalls :
http://www.drtube.com/guitamp.htm
http://www.drtube.com/marshall.htm
Maybe nothing more than Schematics Heaven, but some files are in .gif instead of .pdf if you prefer. And there are sometimes pictures or misc. info.
EDIT : Oops, link already posted here, but i did not find it in the first post ...
JiM
Has thanked: 31 times
Have thanks: 37 times
Re: Tube Amp Links
Postby soulsonic » 27 Mar 2009, 08:58
This place has some good info about British amps. Has good photos of units that were serviced and even some nice schematics.
http://www.chambonino.com
Vampower Mk1! :shock:
http://www.chambonino.com/work/vampower/vampwire2.html
Has thanked: 56 times
Have thanks: 278 times
Re: Tube Amp Links
Postby AbuseArt » 20 Apr 2009, 20:48
Its a Polish site; http://www.mif.pg.gda.pl/homepages/tom/misc.htm
interesting though.
AbuseArt
Re: Tube Amp Links
Postby v846 » 02 May 2010, 19:41
another one,
http://forum.marstran.com/
cool Marshall database + one for cabs
http://forum.marstran.com/viewtopic.php?f=4&t=26
v846
Re: Tube Amp Links
Postby bancika » 04 Jul 2010, 15:51
I'd recommend my site, if you don't mind www.diy-fever.com :roll:
Cheers :thumbsup
bancika
Has thanked: 16 times
Have thanks: 87 times
Re: Tube Amp Links
Postby Ice-9 » 05 Nov 2010, 18:05
Direct from the FENDER webside are official schematics of amps for download
http://www.fender.com/support/amplifier_schematics.php
Ice-9
Has thanked: 143 times
Have thanks: 361 times
Re: Tube Amp Links
Postby sst4270 » 05 Nov 2010, 19:58
I't so funny that I was reading down this two page list and I have every single one of those in my favs folder already.
Pete Millet's site is an immense wealth of literature! I've downloaded so many books from his site. I've emailed him about some old MacIntosh Amps I have. Nice guy.
Here's a several other resources that I've used in the past that I didn't see on the list yet:
http://boozhoundlabs.com/ some great diy tube projects/articles
http://www.dogstar.dantimax.dk/tubestuf/index.htm Fred's site and home of the Real McTube I & II
http://www.harpamps.com/ another great resource of information
http://www.lwharpamps.com/ Some great diy projects and forum for small Harp amps.
And Don't Forget: http://www.brownnote.net/ Hit up the forum for a wealth of information! Some really knowledgeable guys there.
Oh and Finally: http://www.diyaudio.com/forums/ While mostly dealing with Hifi there is a wealth of knowledge there regarding tubes/SS/Speakers, etc...
Enjoy,
Steve
sst4270
Re: Tube Amp Links
Postby starkjo » 28 Jan 2013, 08:22
Hey,
is the service manual and/or schematic for the Vox AC15HW1X available somewhere?
Regards,
John
starkjo
Re:
Postby DrNomis » 28 Jan 2013, 09:40
bajaman wrote:Steve Bench has a great info site too - plus a very good high voltage from low 12vdc inverter, which i have used in a tube mic. preamp successfully.
members.aol.com/sbench101
I tried copying/pasting that link in google but it took me to some website about christmas stuff, looks like Steve moved the site to another place, just thought I'd post this link here:
http://diyaudioprojects.com/mirror/memb ... sbench101/
Has thanked: 123 times
Have thanks: 401 times
Re: Tube Amp Links
Postby sinner » 24 Sep 2013, 00:36
Amp diggers, you gonna love it
Amp Calculators
For this message the author sinner has received thanks: 2
deltafred (24 Sep 2013, 09:01), Ice-9 (24 Sep 2013, 10:04)
Has thanked: 1240 times
Have thanks: 1100 times
Re: Tube Amp Links
Postby sinner » 24 Sep 2013, 00:42
Shit! It links only one calculator... In this case - click on the blue menu called Select Another Calculator and enjoy :)
Re: Tube Amp Links
Postby Brymus » 09 Jan 2015, 01:12
Trinity amps has a great forum and lots of good layouts and schematics for download.
http://www.trinityamps.com/phpbb/index.php
I build a modified version of the Plexi MKII super lead "brown" It is an awesome 18 watt high gain amp. 8)
Brymus
Re: Tube Amp Links
Postby mavrim » 21 Feb 2015, 04:14
BUMP
Many old links that do not work!
mavrim
Have thanks: 24 times
Re: Tube Amp Links
Postby mab » 19 Aug 2016, 16:26
I've been having a lot of trouble getting into 18watt.com. Is it going defunct?
mab
Re: Tube Amp Links
Postby Jan1966 » 19 Aug 2016, 21:11
Yep
For this message the author Jan1966 has received thanks:
mab (01 Sep 2016, 12:08)
Jan1966
Has thanked: 13 times
Have thanks: 16 times
Re: Tube Amp Links
Postby ToneKarma » 25 Mar 2019, 12:26
Schematic Heaven has a new URL:
http://schematicheaven.net/
ToneKarma
Has thanked: 10 times
Have thanks: 2 times
Previous
Return to Amplifiers
