"Murder One" Submini Tube Guitar Amplifier
Re: "Murder One" Submini Tube Guitar Amplifier
Postby frequencycentral » 30 Dec 2011, 14:50
Leodos wrote:The capacitors are 50 v?
All 10uF are 100v
Leodos wrote:The IC may be the next link? http://cl.rsdelivers.com/product/inters ... 46707.aspx
Looks good.
Leodos wrote:The box is a Hammond 1590BB?
I build them into 1590B, but it's a tight build if you're not used to it. Would be easier in a BB.
frequencycentral
Has thanked: 30 times
Have thanks: 68 times
Postby Jayallen » 18 Sep 2015, 01:58
Is it possible to substitute the 5672 tube with a 6112? Thanks
Jayallen
Postby Scruffie » 18 Sep 2015, 02:08
Jayallen wrote:Is it possible to substitute the 5672 tube with a 6112? Thanks
No, the 5672 is a pentode and the 6112 is a dual triode, you'd have to redesign the amp to do that and the 6112 isn't a particularly suitable output tube anyway.
For this message the author Scruffie has received thanks:
Jayallen (19 Sep 2015, 04:07)
Scruffie
Has thanked: 27 times
Have thanks: 139 times
Postby substatica » 01 May 2016, 17:30
Uh, is this how it's suppose to be looking? The PCB images are all the wrong size. Someone said on one of the forums to resize them to 48% but that still didn't size the IC1 for a socket, so I sized it to 35% and the IC socket fits perfectly, but other things are a bit crowded. I etched a couple so this is how it's going to go, caps'll all just have to get along.
substatica
Postby frequencycentral » 02 May 2016, 23:10
Resize to 48% should be correct. Those electrolytic look huge. What size are they? I used 11mm x 5mm.
frequencycentral
Postby substatica » 03 May 2016, 02:51
frequencycentral wrote:Resize to 48% should be correct. Those electrolytic look huge. What size are they? I used 11mm x 5mm.
They measure 12mm x 8mm, it's all the local shop had in 10uf 100V. Did anyone else use an IC socket? I could see IC pins fitting the 48% because you can stretch them out and apart more than a socket, but 35% is the only size that a socket would actually sit in the board.
substatica
Postby Riffmonster » 09 Jul 2016, 12:05
Hello to all,
I am new to the forum so first a huge thanks to all for the efforts you put in the page.
I am new to building gear aswell. I built some non tube stompboxes and had no problems. Now i wanna build the murder one but i feel that i have some concerns.
1. Which safety procedures do i have to obey?
2. Do i need to do voltage readings?
3. Will it work with the common power supply like other pedals?
4. Do i solder the tubes directly on the board or do i use sockets?
Thanks so far. I hope i am not bothering anyone. I really wanna do this and understand what i am doing.
Thanks and cheers from Germany1
Riffmonster
Previous
Return to Amplifiers
Users browsing this forum: Dsmnoisemaker, Google [Bot] and 3 guests
