Zvex - Nano Head
kinski
Has thanked: 10 times
Post by kinski »
Anyone have a layout or pcb of this?!?
culturejam
Has thanked: 433 times
Been thanked: 563 times
Post by culturejam »
There is no layout that I know of, but there is a schematic on page 7 of this thread.
kinski
Post by kinski »
yeah, i just suck at reading schematics......gotta learn sometime.... :hmmm:
rasta_maleek
Has thanked: 52 times
Been thanked: 52 times
Post by rasta_maleek »
kinski wrote:Anyone have a layout or pcb of this?!?
this answer your question
proyecto sub.miniatura.pdf
(1.02 MiB) Downloaded 1052 times
PokeyPete
Been thanked: 43 times
Post by PokeyPete »
After reading this thread I don't remember anyone saying that they had built it with AWESOME results!
This looks like a terrific project. I love to hear the boasts and see the pictures. I'm missing that here.
–Hunter S. Thompson
kinski
Post by kinski »
thanks!
culturejam
This is a layout for the JJS amp, not the Zvex Nano.
rasta_maleek
yes master, but it let him to try the zvexnano schems over the jjs layout with some mods. I did nanoamp mods but didn´t like it, much better tone is coming from the jj´s schem.
leejon
Post by leejon »
Does anyone has the original zvex power supply schematics?
Otherwise any idea how you could make the nixie power supple deliver 230volt??
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 51 times
Post by Hides-His-Eyes »
leejon wrote:Hi,
Not the volts man, it's the volt at that current
frequencycentral
Has thanked: 28 times
Post by frequencycentral »
I use a variation on this for one of my amps:
http://www.desmith.net/NMdS/Electronics/NixiePSU.html
I get 240v, enough for a 12AX7, 12AU7 and O/T. Should work fine for the Nano.
ansil
4 vintage plexi builds
100 jungle kat boosts
5 blues pearl purplexed
Has thanked: 15 times
Been thanked: 13 times
Post by ansil »
hey freq where did you get those a+ tube shields man those are righteous
Has thanked: 596 times
Been thanked: 2061 times
looks like it will work well for rock music - lol
mrkaploca
Been thanked: 12 times
Post by mrkaploca »
Can toroidal inductor be used-100uH/2.5A ?
Ringbox
Post by Ringbox »
I have a preamp with a gain and post volume and want to connect the line output of the preamp to the power section of the Nano.
Considering the schematics provided by biggs(thanks!), I outlined the power section as red and marked the power amp input.
Am I right? Is something else necessary to do it?
lietuvis
Has thanked: 99 times
Been thanked: 86 times
Post by lietuvis »
Ringbox wrote:I have a preamp with a gain and post volume and want to connect the line output of the preamp to the power section of the Nano.
I think the whole point is to build a fuly valve amplifier in a stompbox size enclosure including preamp and power section where the dirt or clean sounds comes from both sections, the power amp might give you about 200mW considering its class A amplifier. By the way the power amp input is the last triode input which is using only half 6021 where the input capacitor would be C10.
lietuvis
Post by lietuvis »
There is my amplifier test video, before it got boxed
Ringbox
Post by Ringbox »
lietuvis wrote:
Ringbox wrote: I think the whole point is to build a fuly valve amplifier in a stompbox size enclosure including preamp and power section where the dirt or clean sounds comes from both sections, the power amp might give you about 200mW considering its class A amplifier.
but, my preamp is also all-tube(4 x 12ax7) , so I need only mini power amp to play at speech levels :D
lietuvis
Post by lietuvis »
but, my preamp is also all-tube(4 x 12ax7) , so I need only mini power amp to play at speech levels :D[/quote]
well then look for schematics over here, pushpull amplifier using 1X6021 is first schematic that I would suggest.
http://www.dmitrynizh.com/submini-vibro-reverb.htm
Brainbender
Completed builds: Fuzz Factory, Shin-ei Fuzz, Sixties Fuzzface, Fender Blender, Bazz Fuss, RAT, Tonebender, SFT, Blue Box, Super-fuzz, Big Muff (many versions), Mosrite Fuzzrite
Has thanked: 20 times
Post by Brainbender »
[smilie=bump.gif]
