My transformer:
Core cross section 20x16 mm
Each half bobbin:
120 turns 0.25 mm (1/4) primary
75 turns 0.5 mm secondary (for 8 Ohm load)
For calculation for your core and load impedance you can use transformer calculator for tube PP.
Enter primary impedance Ra-a 360 Ohm, core parameters, power, load impedance etc.
If you wish to design your own fet PA you can use my program to select primary impedance for desired power and supply voltage
http://milas.spb.ru/~kmg/files/projects/fetpa/Pa.exepa.jpg
Ra - impedance of half primary winding (1/4 Ra-a)
Vsupply - power supply voltage
Sig Max % - signal amplitude (100% is maximum signal without distortion)
Vsat - fet saturation voltage at peak current
Id0 - idle current
Average Pd - Average drain power (for one side of PP, halfwave)
Average Pl - Average load power (fullwave, but without taking into account efficiency of the transformer)
Average Id - Average drain current (for one side of PP, halfwave)
Peak Pd - Peak drain power (instantaneous)
Peak Id - Peak drain current (instantaneous)
