Favorite boost/low gain, amazing pedal?
Postby Beedoola » 01 Feb 2011, 19:21
I've been on my quest for a really good boosty/light OD for sometime. I'm looking for something thats not really TS voiced, or marshall voiced, just something that can let the guitar and amp speak, push the amp. I've also had issues with uneven/fuzzy decay - some circuits worst that others. I think thats my biggest beef with a lot of pedals is the decay, I'm looking for something real smooth. Doesn't need to have a lot of gain on tap, just enough to help push my Ampeg V4. And something that could stack well with fuzzes..
What do you recommend/really like?
Beedoola
Has thanked: 19 times
Have thanks: 28 times
Re: Favorite boost/low gain, amazing pedal?
Postby Hides-His-Eyes » 01 Feb 2011, 19:27
Try an op-amp clipper with a pair of Si diodes each way, treble control via a simple low-pass, and bass control by using a pot to choose between two bass caps from the non-inverting amplifier's -ve input to Vref.
Hides-His-Eyes
Has thanked: 53 times
Have thanks: 84 times
Postby Greenmachine » 01 Feb 2011, 19:36
Hides-His-Eyes wrote:Try an op-amp clipper with a pair of Si diodes each way, treble control via a simple low-pass, and bass control by using a pot to choose between two bass caps from the non-inverting amplifier's -ve input to Vref.
This sounds like a knowledgeable answer; would an example of this be the DOD 250? I'm interested in something like this too.
Greenmachine
Has thanked: 102 times
Have thanks: 19 times
Postby Crumbchildz » 01 Feb 2011, 20:30
For a V4? I'd go Colorsound Powerboost. It's pretty much clean up until the high end of the gain rotation then it jumps into a fuzzy beast. Plus the low and high controls radically effect the gain and tone (obviously). I spent a ton of time trying different boosters and drives with my V4 and the Colorsound won by a long shot.
Loud's a tone, right?
Crumbchildz
Have thanks: 3 times
Postby joeboo88 » 01 Feb 2011, 20:58
i'm with Crumbchildz, but i just built a colorsound overdriver clone, and love putting it b4 my amp, with my bluesbreaker behind it, lovely sounds, what a loud biotch and clear too, until the end then a fuzzy biotch :D
Ebay is a fucker ~ Sinner - If this is something unique, then I'm a teletubbie ~also Sinner
joeboo88
Has thanked: 276 times
Have thanks: 16 times
Postby dennism » 01 Feb 2011, 21:03
How about the Electra? Heck, it's only about 8 components, worth a try to breadboard it.
dennism
Postby merlinb » 01 Feb 2011, 22:16
merlinb
Have thanks: 164 times
Postby GuitarlCarl » 02 Feb 2011, 00:05
Simple clean no color boost.... slam it with a LPB-1. That's about as simple as it gets. Sounds like my guitar, and sounds like my amp, just more of it! Early 80's I used to run a 59' LP jr into a LPB-1 into a Morley echo into a Bassman 100. Simple is good.
GuitarlCarl
Has thanked: 69 times
Have thanks: 31 times
Postby Greg » 02 Feb 2011, 01:47
merlinb wrote:Genuine valve Tubescreamer? :mrgreen:
http://s81.photobucket.com/albums/j207/ ... 1%20PEdal/
That looks very cool.. I'll have to try it when I get a chance.
I'd really love to hear a clip or two.
Greg
Has thanked: 77 times
Have thanks: 195 times
Postby Tonetweaker » 02 Feb 2011, 03:45
GuitarlCarl wrote:Simple clean no color boost.... slam it with a LPB-1. That's about as simple as it gets. Sounds like my guitar, and sounds like my amp, just more of it! Early 80's I used to run a 59' LP jr into a LPB-1 into a Morley echo into a Bassman 100. Simple is good.
I'd agree with that... It certainly doesn't color the sound much. A good kick without much change in tone, even cranked.
In Soviet Russia, dirt box fucks YOU!! ~ Seiche
Tonetweaker
Has thanked: 25 times
Have thanks: 59 times
Postby Beedoola » 02 Feb 2011, 03:56
I'm not looking for a total boost pedal. I'd like it to have some gain on tap. I'd also be using it with my small 1x10 combo.
Beedoola
Postby MoonWatcher » 02 Feb 2011, 05:08
Beedoola wrote:I'm not looking for a total boost pedal. I'd like it to have some gain on tap. I'd also be using it with my small 1x10 combo.
I'd say that the LPB-1 is good for that, too. It will get a bit of growl going at higher settings. For a lot of fun, cascade one into another for some mild snarl.
MoonWatcher
Has thanked: 43 times
Have thanks: 65 times
Postby Beedoola » 02 Feb 2011, 06:03
I tried a Zvex Super Duper and didn't like how it sounded cascaded or even with the just the one master volume SHO, the decay was very loose and nasty. I know you mentioned LPB-1 but I guess I'm assuming they're similar, or enough to maybe yield the same results..?
Beedoola
Postby Beedoola » 02 Feb 2011, 06:21
what about a Bluesbreaker or KOT clone?
Beedoola
Postby RnFR » 02 Feb 2011, 07:37
you might like this one.
http://apocalypseaudio.blogspot.com/201 ... drive.html
it's very transparent, and is kind of similar to the CSO, minus the EQ of course. it also works excellent as a buffer.
Has thanked: 150 times
Have thanks: 174 times
Postby blackbunny » 02 Feb 2011, 16:43
It sounds like you need a Timmy. Come to think of it, everybody should have at least one.
blackbunny
Has thanked: 269 times
Have thanks: 111 times
Postby GuitarlCarl » 03 Feb 2011, 06:36
From a different thread...
culturejam wrote:By now some of you must have seen this:
http://www.thegearpage.net/board/showth ... p?t=840912
It's got a clip of the new mystery Klon (in a cardboard box).
35 minutes long, 30 different overdrives...
I think the real question is do you want any color in your drive or clean boost?
Originally it sounded like you wanted to hear your guitar and amp... but we all know there's a little color in any pedal...so check out the video...All the overdrives sound similiar, but the differences are there for you to decide.
My board has a DS-1 modded into tubescreamer territory and no diodes just alot of BOOST.
So that's another idea... Ds-1's are dirt cheap and easy to mod and remod and remod and remod.... :hmmm:
GuitarlCarl
Postby billonious » 03 Feb 2011, 20:29
so, you want something more of a booster than of an overdrive, let's say a very slightly overdrive, soft & transparent enough. I think of Barber ltd. Take a look http://www.youtube.com/watch?v=wFQJulI6rQg
billonious
Have thanks: 9 times
Postby Hides-His-Eyes » 03 Feb 2011, 22:01
I already said that, I just chose my words carefully :)
Hides-His-Eyes
Postby Beedoola » 03 Feb 2011, 23:54
haha, I had no idea what you were talking about, thats why I didn't reply. Looks like I may need to build a Timmy...
Beedoola
Next
Return to Freestomp Café!
