Building a multi-effect unit (a la Cornish, etc.)
Re: Building a multi-effect unit (a la Cornish, etc.)
Postby reneshelle » 22 Apr 2011, 22:05
Then just ad the loop if he wants it. The switched jack solution is superb. I personally run my wah first so...
reneshelle
Has thanked: 38 times
Have thanks: 52 times
Postby DaveKerr » 22 Apr 2011, 22:09
If you know where in the chain you'd want to insert an effect, it shouldn't be all that tough, should it? Just throw in a couple switched jacks for send/return?
DaveKerr
Has thanked: 65 times
Have thanks: 11 times
Postby Dr Tony Balls » 22 Apr 2011, 22:13
ahhhh I suppose thats true! A simple post-dirt effects loop would do the trick. You're either gonna want to add something before the dirt, in between the dirt and the modulation, or after the modulation. So in that case you could really just do one following the fuzz/boost. awesome!
Dr Tony Balls
Have thanks: 153 times
Postby GuitarlCarl » 23 Apr 2011, 02:27
A bank of dip switches could decide if you want to stay connected internally, or go to external jacks. OR maybe just an extra stompswitch to turn on the external loop for off board pedals... I do agree with the earlier post, if you keep each effect on its own board, you can rewire the order of the pedals inside without physically moving your pots and stomps around... as far as overdrive before or after the distortion you could as easily switch your dist diodes in and out with another switch, effectively turning the dist into an overdrive. I've been thinking along similar lines, dis/drive then modulation then echo, but the external loop idea...yeah...after the modulation.
GuitarlCarl
Has thanked: 69 times
Have thanks: 31 times
Postby reneshelle » 23 Apr 2011, 06:50
Dr Tony Balls wrote:ahhhh I suppose thats true! A simple post-dirt effects loop would do the trick. You're either gonna want to add something before the dirt, in between the dirt and the modulation, or after the modulation. So in that case you could really just do one following the fuzz/boost. awesome!
That's the way to go I would think. I have a Boss be-5m and the idea here is almost the exact same. the boss can be programed but I always put it in manual mode. I would prefer to own the be-5 (no M) because of the simplicity actualy.
I would not bother making the loop to begin with. I never use the loop on my be-5m. But that's just my way of using it. Others do other things. And otters do otter-things I suppose.
I'm not funny before 8 in the morning it seems...
reneshelle
Postby Dr Tony Balls » 23 Apr 2011, 17:18
reneshelle wrote: And otters do otter-things I suppose.
HA! I laughed.
Dr Tony Balls
Postby Dr Tony Balls » 27 Apr 2011, 15:41
THANKS for your help and ideas, everyone!!!
Everything came out great, and as usual, I got so excited with it that I forgot to take gut shots before I delivered it. The single effects loop after the dirt was totally the right way to go! Simple, yet it allowed for function where you needed it.
Here's the finished product. From right to left (input to output): fuzz face, double boosters (one always on), effects loop send/return, analog delay, tremolo, phase 45:
Dr Tony Balls
Postby Hides-His-Eyes » 27 Apr 2011, 15:45
very smart looking, well done!
Hides-His-Eyes
Has thanked: 53 times
Have thanks: 84 times
Postby Greenmachine » 27 Apr 2011, 19:44
Hides-His-Eyes wrote:very smart looking, well done!
+1 :applause:
Greenmachine
Has thanked: 102 times
Have thanks: 19 times
Postby p_wats » 27 Apr 2011, 20:16
Very nice. I've built a few simple multi-effects, but never this involved. The effects loop is a great idea!
Hell, I'd just love to get my hands on a bunch of those enclosures! Nice job.
p_wats
Have thanks: 3 times
Postby Duckman » 27 Apr 2011, 20:21
Well done! Congrats! :applause:
Gut shots?
Duckman
Has thanked: 369 times
Have thanks: 131 times
Postby reneshelle » 27 Apr 2011, 20:29
:applause: Turned out very nice. Nothing like a usefull piece of gear! :applause:
Hope your friend loves it!
reneshelle
Postby Dr Tony Balls » 27 Apr 2011, 21:53
p_wats wrote:Hell, I'd just love to get my hands on a bunch of those enclosures! Nice job.
The enclosures arent hard to get ahold of, but they arent cheap!
http://angela.com/hammondwalnutchassisa ... anels.aspx
http://angela.com/hammond1431seriesstee ... assis.aspx
Dr Tony Balls
Postby Duckman » 25 Oct 2012, 05:50
You always can put some switched jacks where the wha is supposed to be inserted.
If you don't plug anything, the signal just flows.
Oh, wait...2011?... Dammit, you've already solved, right?
Duckman
Postby myonus » 25 Jan 2018, 20:27
Try a modular approach- like a old Moog Synthesizer. remove, change order, excempt, insert, bus out, etc at will. 8) :hmmm:
Gibson RD Artist Sunburst 1977
Serial: 73127030
Built in: 08-nov-1977 (serial: 030) (Manufactured in Kalamazoo)
Marshall VS100 Valvestate Combo
myonus
Postby Jan1966 » 25 Jan 2018, 20:39
You are replying to a thread that is 5 years old. maybe you will maybe you wont have your advice taken.
Jan1966
Has thanked: 13 times
Have thanks: 16 times
Postby myonus » 25 Jan 2018, 22:05
Jan1966 wrote:You are replying to a thread that is 5 years old. maybe you will maybe you wont have your advice taken.
Yes, i figured as much, but i at least wanted to share the idea to the string :)
Serial: 73127030
myonus
Postby ballfire » 21 Mar 2018, 09:13
just buy a guitar multi effects..you can swap the effects and it has loop settings..
for example a zoom pedal...
ballfire
Has thanked: 28 times
Postby soulsonic » 15 May 2018, 03:51
wish the pics weren't gone. I'm curious what it looked like.
Still haven't done the multieffect box I've wanted to do for years. Haven't been gigging playing guitar in at least the same amount of time so it doesn't seem like a good use of my time. Still want to do it sometime, though, just for kicks.
Has thanked: 56 times
Have thanks: 278 times
Postby Dr Tony Balls » 15 May 2018, 13:51
Sorry.....had to lose and remake my Flickr account. Dont think I have any guts from the original one but here are some pics:
And while looking for those pics I found this one I did sometime later for someone else. From R-L thats a muff variant, an octaver, and a delay with momentary slam switch.
Dr Tony Balls
Previous
Return to Freestomp Café!
