Looking for an in-line "no hum" box for a second amp
Postby Dr Tony Balls » 29 Oct 2011, 21:43
Hi all....
I'm looking to connect two amps at once and avoid the traditional hum associated with ground loops. I've built the geofex hum-free ABY before and it works great as a switcher but I really dont need to have all of the switching. I have a main amp, and then I'd like to connect a second which will always be on, no switching needed. I'm thinking that one could build a stripped down version of the hum-free ABY which would sit in line between the signal cable to the second amp, and the amp itself. Does that make sense?
Has anyone heard of such a thing or know of a schematic for one? Alternatively, looking at geofex schematic, what could one eliminate to do the inline version?
http://www.geofex.com/FX_images/humfree2.gif
Dr Tony Balls
Have thanks: 153 times
Re: Looking for an in-line "no hum" box for a second amp
Postby phatt » 30 Oct 2011, 06:56
In that case it maybe as simple as cutting the ground on the cable that goes to the 2nd Amp.
As long as both amps are grounded then it should work.
There will be some situations where it may not work,,, suck it and see :|
Building the powered splitter box is the better option. :wink:
Phil.
phatt
Have thanks: 251 times
Postby drbob1 » 30 Oct 2011, 19:18
The best solution is usually to have one of the outputs transformer isolated. That said, the Ebtech hum eliminator (inline version) is pretty cheap, hard to imagine being able to build one for less... That said, at guitar frequencies is any 1:1 transformer workable?
drbob1
Have thanks: 47 times
Postby roseblood11 » 30 Oct 2011, 21:49
No, most transformers will kill some highs.
I decided to buy a used Lehle P-Split some years ago and it works great.
Not cheap, but worth the money. When one of the switches didn't work perfectly, I asked Burkhard Lehle what type of switch that was and where I could get them. He send me two pieces for free.
roseblood11
Has thanked: 339 times
Have thanks: 306 times
Postby Seiche » 31 Oct 2011, 21:15
roseblood11 wrote:No, most transformers will kill some highs.
I've been looking for alternatives to the Lehle stuff, as it is rather pricey. Is it just that his transformers are sooo good, or is there another reason why they work so well?
Seiche
Has thanked: 241 times
Have thanks: 181 times
Postby Dr Tony Balls » 06 Dec 2011, 16:29
FYI here's a gut of the Lehle P-Split. It doesnt help much because its just a transformer, but thought i'd share.
Makes me wonder what a passive iso would sound like using one of the transformers from the geofex hum-free ABY (mouser p/n 42TM018)
Dr Tony Balls
Postby ilcaccillo » 03 Jun 2016, 01:16
Looks like an OEP transformer, but with Lehle silkscreened into the MU Metal shield.
ilcaccillo
Have thanks: 18 times
Postby tictac » 04 Jun 2016, 18:11
I'm working on a stripped down version of the humfree and I'd share the picture but there doesnt seem to be an image upload option in this post.... :scratch:
TT
tictac
Have thanks: 9 times
Postby ilcaccillo » 23 Jun 2016, 21:33
tictac wrote:I'm working on a stripped down version of the humfree and I'd share the picture but there doesnt seem to be an image upload option in this post.... :scratch:
TT
Use photobucket.com to upload the pictures there.
Then you just copy the photo Link from photobucket and in the message reply windows here, you have an option on top that say "Img" click there and paste the photo link.
Its easy and simple
ilcaccillo
Return to Freestomp Café!
Users browsing this forum: No registered users and 6 guests
