dr boogie
dr boogie
Postby caburron1ero » 13 Apr 2015, 23:34
hi fsboxes,can the dr boogie pedal be made the other way ,with valves that is,i ve heard the drb on youtube,sounds like those early digitech multieffects.the article on fetzers on runofgroove.com says so.what modification can take place.thanks
caburron1ero
Re: dr boogie
Postby FiveseveN » 14 Apr 2015, 09:36
I hear Mesa Boogie makes something like that.
FiveseveN
Has thanked: 125 times
Have thanks: 47 times
Re: dr boogie
Postby caburron1ero » 14 Apr 2015, 19:25
wisegay or not.
caburron1ero
Re: dr boogie
Postby modman » 14 Apr 2015, 21:49
caburron1ero wrote:wisegay or not.
:shock: :hug:
you want tube, you make tube, like real baja tube
Has thanked: 3081 times
Have thanks: 534 times
Re: dr boogie
Postby sinner » 14 Apr 2015, 23:30
This is the whole point no to use valves. To make it compact you have to go with solid state. It wouldn't be possible to do it on valves in that form. Valves need high voltage to operate, more room to keep it cool, more advanced filtering and power supply
But it is possible - just build the DR preamp channel of your choice and finish it with FX Loop's buffer stage preceded with volume control
Has thanked: 1239 times
Have thanks: 1099 times
Re: dr boogie
Postby caburron1ero » 16 Apr 2015, 00:21
no way jose ,dont like the sound of transistors,nor digital stompboxes like digitech,zoom.i have tested them ,i like vox tonela st, the sound is fantastic maybe becouse the valve 12ax7.i will have to buy 3 12ax7 and then implement the dr boogie and see what happens.
caburron1ero
Re: dr boogie
Postby grrrunge » 16 Apr 2015, 08:17
sinner wrote:This is the whole point no to use valves. To make it compact you have to go with solid state. It wouldn't be possible to do it on valves in that form. Valves need high voltage to operate, more room to keep it cool, more advanced filtering and power supply
+1 :horsey: If you want a Dr Boogie built with tubes, build yourself a Dual Rectifier preamp, and be done with it.
grrrunge
Has thanked: 59 times
Have thanks: 207 times
Re: dr boogie
Postby soulsonic » 05 May 2015, 17:28
+2 Seriously! Dr. Boogie is just a JFET version of the Dual Recto... if you want actual tube version of the Dual Rectifier, then just build the original.
Has thanked: 56 times
Have thanks: 265 times
Return to Freestomp Café!
Users browsing this forum: Google [Bot] and 6 guests
