marshall mg10 amp
marshall mg10 amp
Postby ballfire » 12 Oct 2016, 12:14
hello every body..
im planning to build a marshall mg10 practice amp i dont know what transformer using to this amp how many amperes should i use for my transformer?? my outlet is 220 volts..and what fuse i will use for this transformer how many ampere also it is 3 amperes?? or higher or lower??
thanks for the advice ..
ballfire
Has thanked: 17 times
Re: marshall mg10 amp
Postby ballfire » 22 Oct 2016, 01:38
..poor me,.. nobody reply on my post..i guess everybody is busy..
ballfire
Postby ppluis0 » 22 Oct 2016, 02:40
Hi Ballfire,
A complete explanation and schematic for this amp can be found at: http://www.electrosmash.com/marshall-mg10
A picture in that page shows an transformer with a secondary of 12.6+12.6 volts
Also in the data sheet of the output chip used in this amp ( http://www.st.com/content/ccc/resource/ ... 000129.pdf ) the manufacturer details the behaviour of an 50 watts transformer suggested for this IC
That power looks to be in accordance with the size of the original tranny appeared in the picture.
I guess that the fuse to place in a 220 volt environment to feed a 50 watt transformer will be roughly of 1 Amp
Good luck with your project !!
ppluis0
Has thanked: 34 times
Have thanks: 71 times
Postby ballfire » 28 Oct 2016, 03:10
hi everybody.
thanks to ppluis0..thank you very much for the reply..
ballfire
Postby thereminator » 29 Oct 2016, 22:50
MG10? Awful sound.
It is better to build a clone of Marshall Lead 12 from 80's.
http://www.drtube.com/schematics/marshall/3005.gif
In theory, theory & practice are the same - in practice, they aren't.
thereminator
Have thanks: 4 times
Postby okgb » 06 Nov 2016, 17:00
I haven't heard an MG that sounded good, so that seems like effort for nothing, maybe more research this more first
maybe an established project so there is already some support ?
okgb
Has thanked: 190 times
Have thanks: 41 times
Return to Freestomp Café!
