questions about subminiature valves.
Postby mildew » 07 Dec 2016, 03:54
Im going to attempt to replace the 6205 valve in my groovetube brick mic preamp.
Its soldered in, so im quite worried about mucking it up.
The valves with pins only go in one way - how do you know with a subminiature which leg is leg 1, and what rotational orientation its placed in?
Im replacing a groove tubes 6205 with a sylvania nos 6205.
thxinadv
mildew
Re: questions about subminiature valves.
Postby tonyharker » 07 Dec 2016, 11:05
There's a gap between pins? 1 & 8. Holding upside down pin 1 is on the left. See datasheet.
tonyharker
Have thanks: 9 times
Postby ppluis0 » 08 Dec 2016, 02:29
mildew wrote:The valves with pins only go in one way - how do you know with a subminiature which leg is leg 1, and what rotational orientation its placed in?
Take a look at page 6 of this datasheet: https://frank.pocnet.net/sheets/129/6/6205.pdf
ppluis0
Has thanked: 34 times
Have thanks: 71 times
Postby mildew » 08 Dec 2016, 03:57
thanks for the replies, i now realise that the subminiatures have the extra gap between the first and last pin just like the bigger valves.
mildew
Return to Freestomp Café!
Users browsing this forum: Steeler [Crawler] and 5 guests
