Battery in or out?
Battery in or out?
Postby tele twister » 08 Jan 2017, 00:11
I've been wondering this, for a very long time, is it better to leave the battery in, or out, when solely using adapters to power it?
I'm aware of the "in case the plug falls out" phrase, but these pedals are nailed to a board (so to speak), so there's a slim chance that would happen.
And if it did, the battery is probably dead anyway, from always having a cord in the input.
What if the battery is oozing acid in there...I'll have to get the claw hammer out :wink:
tele twister
Have thanks: 3 times
Re: Battery in or out?
Postby Manfred » 08 Jan 2017, 00:55
Leave the batterie out.
If the battery is aged, electrolytic fluid in it may leak, which would damage this device.
For modern alkaline batteries it happens only rarely, but it happnes.
Manfred
Has thanked: 959 times
Have thanks: 505 times
Postby phatt » 09 Jan 2017, 08:42
tele twister wrote:I've been wondering this, for a very long time, is it better to leave the battery in, or out, when solely using adapters to power it?
No the moment you plug in a external supply it disconnects the battery,, if it did not the battery would explode. :shock: Wise to remove batteries if not used. :secret:
Phil.
phatt
Have thanks: 252 times
Postby tele twister » 14 Jan 2017, 07:09
Thank you folks, I appreciate your replies.
tele twister
Return to Freestomp Café!
