Just want to say thanks to all you folks!
PostPosted: 07 May 2017, 01:48
by mistermikev
Really grateful for this site. Learned so many things lurking here.
Just finished a wet cat. Had a hard time tracing the audio path as I wasn't sure if it should match the dm2 schematic. Realized my 571 was backwards and things started to make more sense. traced a little further and found wrong orientation for q4 transistor in delay path on the mn3005 layout (picture)... but the pins were right and now that I think about it that might be mentioned somewhere in the thread.
Very thankful to baja and others who did the work for projects like this. You guys are really great for sharing.
Re: Just want to say thanks to all you folks!
PostPosted: 07 May 2017, 10:52
by bajaman
you are most welcome - glad you got it sorted :D
PostPosted: 07 May 2017, 19:17
by mistermikev
your projects are like gold baja. guaranteed to work as long as you follow the bouncing ball.
I have a sabre2 in 3 guitars and a stingray in 3 basses.
been thinking about attempting the real tube project but it looks like you almost need welding skill to do that!
