DRILL BIT
DRILL BIT
Postby black03 » 04 Sep 2018, 15:36
hi, does anyone have any idea how to make a square hole in a 1590B box?
There is some drill bit for square holes, I saw on ebay but they are for wood.
Thank you
black03
Re: DRILL BIT
Postby tonyharker » 04 Sep 2018, 20:31
Drill a round hole then file it square using needle files.
tonyharker
Have thanks: 11 times
Re: DRILL BIT
Postby Sooner Boomer » 05 Sep 2018, 00:16
How big of a hole? If it's bigger than 3/8" you can drill 3/8 (or a hole near the size you need) then use a nibbling tool to remove the rest. They also make Greenlee punches that make square holes, but theyre very expensive.
Sooner Boomer
Re: DRILL BIT
Postby deltafred » 05 Sep 2018, 08:06
You can "chain drill" (lots of small holes almost touching each other and the outline of the shape you require) with a small drill then finish off with a file. The more precise you are with your marking out and drilling the less filing you have to do.
This works for any shape.
deltafred
Has thanked: 380 times
Have thanks: 259 times
Re: DRILL BIT
Postby lolbou » 05 Sep 2018, 15:17
For a large rectangular hole (battery drawer à la Cornish) i've used the Dremel cutting disk with success and verry little filing...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lolbou
Has thanked: 347 times
Have thanks: 240 times
Re: DRILL BIT
Postby black03 » 07 Sep 2018, 02:43
thanks guys for answering, but it is not for making a single hole, I need to make 10 square holes for the dc that goes to the pcb, as big brands do.
some tool must exist, right?
black03
Re: DRILL BIT
Postby deltafred » 07 Sep 2018, 10:24
The big brands probably stamp them out using a punch and die in a press or get the boxes die cast with all the necessary holes preformed, not really viable for 10.
There are square drills for wood, a square chisel with a drill in the centre. They are used for cutting mortises and are used in a proper mortising machine. The drill makes a round hole and the chisel cuts out the corners. This works for wood because the wood cuts relatively easily and chisel does not take a lot of force to cut out the corners.
To do the same with metal would take a take many times the force. It might work but for thin metal a punch and die are more suited to the job.
deltafred
Re: DRILL BIT
Postby Fender3D » 07 Sep 2018, 11:50
Actually a square hole drill bit exists, sadly I don't know where you can get it...
Link
Fender3D
Has thanked: 97 times
Have thanks: 131 times
Re: DRILL BIT
Postby phatt » 07 Sep 2018, 14:55
Clever invention,,,but even if you could afford that drill bit the magic is in the offset drilling machine which would cost a fortune. [smilie=a_holycrap.gif]
@black 03; if it's a one off project just wear the pain and file the 10 holes or consider changing to the round hole DC sockets.
Phil.
phatt
Have thanks: 264 times
Re: DRILL BIT
Postby Fender3D » 07 Sep 2018, 15:58
^^ +1
otherwise find a friend with a laser cutter, make a plexi template, and drill round holes..
Fender3D
Re: DRILL BIT
Postby black03 » 11 Sep 2018, 00:52
Thanks for the answers.
Only with money life is easy ...
black03
Re: DRILL BIT
Postby Cub » 11 Sep 2018, 08:45
What about this then?
Link
Cub
Has thanked: 73 times
Have thanks: 85 times
Re: DRILL BIT
Postby Sooner Boomer » 11 Sep 2018, 10:35
black03 wrote:thanks guys for answering, but it is not for making a single hole, I need to make 10 square holes for the dc that goes to the pcb, as big brands do.
They would either use a punch or a square broach reamer. A broach is like a file with widely spaced teeth. You might be able to find one cheaply enough for your purpose. But, I think a lot of hand filing is in your future...
Sooner Boomer
Re: DRILL BIT
Postby deltafred » 11 Sep 2018, 12:28
black03 wrote:Only with money life is easy ...
Correct.
Quit putting it off and get filing! :lol:
deltafred
Return to Freestomp Café!
