VeroRoute - Free layout software for Vero, Perf, & PCBs
Postby DrAlx » 22 Jun 2017, 11:06
Written by me. It's free and will remain so. I'm calling it a Beta until I receive enough feedback that it is being used OK with no problems.
The main page is here...
https://sourceforge.net/projects/veroroute/?source=navbar
Precompiled versions are available for Windows 7 (32-bit and 64-bit) here...
https://sourceforge.net/projects/veroroute/files/?source=navbar
There is no installer. Just unzip to a folder and run the exe.
I recommend following the in-built tutorial under Help->Tutorial.
The more feedback I get, the quicker it will improve.
For this message the author DrAlx has received thanks: 2
bmxguitarsbmx (04 Jul 2017, 23:12), modman (23 Jun 2017, 09:58)
DrAlx
Have thanks: 3 times
Re: VeroRoute - Free layout software for Vero, Perf, & PCBs
Postby Dirk_Hendrik » 12 Jul 2017, 08:34
As a full time electronics CAD system userI always have a tremendous respect for people choosing to make applications like these. It's a shitload of work. Therefore some remarks;
- What did make you decide to make an application like this? There's quite a few CAD systems available including those targeted at Veroboard
- Whay did make you decide , unless I operated the application wrong, to start off from PCB layouting straight away without going through schematic and netlist phase. This approach kills all portability of a design to a different form as well as all forms of error checking.
- As well, I tend to judge PCB cad systems by 2 initial factors: How are libraries made and how easy is it to edit add components to that library oneself? As far as I see now the possibility to add or edit components is in the hands of the programmer.
In other words, when going further with this project look at how the big boys do it. In structure of the CAD system, and then in functionality.
Has thanked: 249 times
Have thanks: 988 times
Postby DrAlx » 12 Jul 2017, 12:20
Dirk_Hendrik wrote:As a full time electronics CAD system userI always have a tremendous respect for people choosing to make applications like these. It's a shitload of work. Therefore some remarks;
First ,thank you for the feedback. I have had very little.
You say it's a lot of work to make an application like this but the whole thing is only 6500 lines of code. If I rolled the code back to the most basic vero functionality (which is all I used for several years) you could halve that figure. I don't know if you are a programmer or not, but that is very little code and it did not take me that long to write.
Dirk_Hendrik wrote:What did make you decide to make an application like this? There's quite a few CAD systems available including those targeted at Veroboard
I've only ever built on vero and perf and the software was primarily written to help me do that.
I realised that I could easily do a code modification to draw PCB style tracks so I added it.
By including the PCB mode, it means I can post a vero layout to a forum such as this one, but also post an etch-it-yourself style PCB layout (for those who like to do that) with no extra effort. All it takes is a few mouse-clicks.
I have a particular way of building things on vero. I only ever break strips between holes and I always use solder bridges to join adjacent tracks instead of jumpers.
I used to do layouts by hand but it was very tedious and error prone. Most of the time was spent verifying connectivity.
I wanted software that would:
  • Let me easily add & manipulate components without hunting through menus.
    That's why I have a single control panel with practically everything in it.
  • Dynamically check and visualise connectivity while the circuit is manipulated.
  • Have the program tell me where to make breaks in the vero strips.
  • Have the program tell me where to bridge strips together with solder.
For the sorts of circuits I build, learning a full electronics CAD package (e.g. Eagle, KiCad, etc) and finding a way to use it to produce a vero layout would have been total overkill. They contain way more functionality than I would ever need.
I wanted something that was as easy to use as DIYLC. I like DIYLC and it is a nice drawing program, but what stops it being useful for me is the lack of any connectivity checking or visualisation. There are hundreds of "unverified" DIYLC layouts out there, and I suspect that is largely down to this lack of connectivity checking. If DIYLC had connectivity checking I may have never written my own program.
All the other vero software I have seen starts with a board of strips to which you add components, make breaks, and add jumpers. That would be the way you do things if you have a board physically in front of you and were laying out parts, but to my mind it is not the best way to approach the layout problem algorithmically. Also, not all vero programs had routing or connectivity checking. At least not in the way I wanted it to work. My approach is this...
  • Start with an empty board with no strips.
  • Lay out the components as they appear in the schematic.
  • Graphically specify the netlist by clicking on the component pins.
  • Manipulate the components to minimise area (using the auto-routing to make connections).
  • Finally, switch on "Vero" mode in the software and let it tell me where to make the strip breaks and solder bridges.
Dirk_Hendrik wrote:- Whay did make you decide , unless I operated the application wrong, to start off from PCB layouting straight away without going through schematic and netlist phase. This approach kills all portability of a design to a different form as well as all forms of error checking.
I don't know if you ran through the in-built tutorials ? (Help->Tutorials)
There is a netlist in the tool. You can't do auto-routing or connectivity checking without it. Having this sort of error checking was the reason I wrote the software in the first place.
You can import/export the netlist but it is my own text format. I could add import from some other format like LTspice but it's not a priority at the moment. I reckon anyone whose using something like LTspice would probably be using a full EDA package to produce boards anyway.
The way you specify the netlist in the program is graphically at the beginning of the layout.
There is an example in the tutorials of a simple NPN amplifier.
The idea is that you do not go straight to the final layout. Instead you start by placing the parts just as they appear in the schematic.
Think of this as the "schematic drawing stage". Apart from ICs, there is not that much difference between drawing a schematic symbol and drawing a component outline.
Once you have the parts laid out as in the schematic, you specify the netlist graphically by "painting" netlist values to the component pins using mouse clicks. That is the "netlist specification stage".
So long as you specify the netlist correctly, you can then manipulate the parts however you want and the program will prevent you from making short-circuits and will warn you about open-circuits.
Dirk_Hendrik wrote:As well, I tend to judge PCB cad systems by 2 initial factors: How are libraries made and how easy is it to edit add components to that library oneself? As far as I see now the possibility to add or edit components is in the hands of the programmer.
I tried to cover the majority of parts that you would have on a vero build. It would not be difficult to add a footprint editor and it's on my to-do list.
modman (17 Jul 2017, 20:48)
DrAlx
Postby lcv » 16 Jul 2017, 17:02
Hi DrAlx
Thanks for sharing this SW.
I did spend some time experimenting some of its features ( I went through the tutorial [btw your NPN example won't bias correctly] , put together some components etc.)
Now,apart from the SW itself , I have a fundamental issue on how the tracks, after auto-routing, are mapped to veroboards , i.e. through cuts between the holes and solder bridges between adjacent strips:
1) I have difficulties obtaining clean, repeatable cuts between holes on a strip. Cutting at the holes is much cleaner.
2) Solder joints: I tried, but they just don't happen, and surely they are not elliptical :-) . Solder spreads around (as it should) and then by adhesion it regroups on the metal (as it should). To me solder bridges barely works across two perf pads. Low temperature solder shaping is not a reliable practice IMHO.
Given that nothing is done algorithmically to reduce the number of cuts or bridges, I think that my vero for a not-trivial circuit will look a real mess underneath.
On the other hand, mapping in this way the tracks on the vero, it really improves on the control you can have on the vero tracks path , e.g. grounds tracks etc.
But simply , using veros the way you suggest is above my current ability.
Probably I am missing something...
Thanks again,
Best Regards,
Lvc
lcv
Have thanks: 4 times
Postby DrAlx » 17 Jul 2017, 11:51
lcv wrote:Hi DrAlx
Thanks for the feedback Lvc. I fixed the nonsense NPN example in the latest version.
Yes, the software is geared towards my own style of building on vero and it won't be for everyone. I use that style because it leads to more compact builds.
If you want to avoid strip breaks and cut out a hole instead (i.e. a whole grid square) then you will have to manually erase the grid square to do that.
In fact when I first wrote the software, I did not have any sort of auto-routing and just painted in the strips manually.
The software still does the most important thing which is to check connectivity.
My own technique for strip cutting / bridging is this.
    I make all strip cuts before any of the parts are put in the board.
    The first thing I do is mark all the break points with a black sharpie marker and double check against the layout.
    To cut a strip, I make 2 close parallel cuts with a sharp knife (what we call a Stanley knife in the UK) and then remove the inked portion between the two cuts.
    I also manually edit the locations of the strip breaks in the software to try and make the cuts line up so that I can cut several strips in one go.
    Once I have done the whole board, I check it for shorts using a multi-meter.
    Bridging strips with just solder is not easy (as you mention) and wastes a lot of solder too. So I don't do that. What I actually do is bend the component legs (after they have gone through the hole but before they are soldered) and use them to make a bridge to the neighboring strip. So long as you keep the legs short and bridge just one strip instead of several, then desoldering in future is not a problem.
    The software already favors putting bridges in places where there are component pins for this very reason.
    The software also tries to avoid doing that in places where there is only a pad for off-board wiring. The reason being that you don't want the act of adding/removing an off-board wire to de-solder a connection between strips.
DrAlx
Postby DrAlx » 17 Jul 2017, 14:37
Here is an example of a board I built a few years ago.
This one was actually a messy build, but amazingly worked first time with no errors after soldering.
Sharpie marks: https://1drv.ms/i/s!AvrH61utWEtEh1hcRXPEcCanY11o
After cutting strip breaks: https://1drv.ms/i/s!AvrH61utWEtEh1eJQgOkBu8QwM6N
After I make the parallel cuts, I remove the copper by pushing a jewellers screwdriver along the break to make sure there is no material left.
DrAlx
Return to Software Room
