SPICE software
SPICE software
Postby Brian M » 20 Apr 2011, 09:22
I've tried out LT spice a couple of times. It seems ok for signal tracing, but I'm more interesting in simulating frequency response of a circuit. If there are variables (like potentiometers) in the circuit it's a pain to set up correctly, and I don't think I've ever seen a result that looked correct when graphed (probably user error) The shortcut keys are also really annoying. Come on, control Z should always be undo. :roll:
Any suggestions for something a bit more user friendly that is either free or affordable? I don't need anything super powerful.
I downloaded the TINA demo, which looks promising (uses shortcut keys that make sense) but the full version is $480.
Brian M
Have thanks: 54 times
Re: SPICE software
Postby deltafred » 20 Apr 2011, 09:42
I use QUCS running under Ubuntu. As with most things Linux the user manual is 'make it up as you go' but once you download a few examples and see how other people have done things it starts to get a lot easier. It is free.
My trouble is I only use it every few months and I have forgotten most of it each time (it's an age thing).
QUCS - Quite Universal Circuit Simulator.
deltafred
Has thanked: 412 times
Have thanks: 265 times
Re: SPICE software
Postby Brian M » 20 Apr 2011, 10:05
cool, i'll check it out. I have ubuntu on my laptop but rarely boot in to it.
I have the same problem with LTspice. I rarely use it and when i do I have to re-learn everything. It doesn't help that it makes everything super tedious.
Brian M
Re: SPICE software
Postby phatt » 20 Apr 2011, 14:13
Hi Brian,
Try Circuitmaker (student version is free but only does 50 components)
http://my.ece.ucsb.edu/bobsclass/2C/Sim ... _maker.htm
I messed around with a few programs but kept coming back to Cmaker because it did the basic stuff so easy.
A couple of fiddly presets have to be made to do the freq plots you mentioned but still a lot easier to work with than some of the high end stuff.
Oh you can sim Valves Also. :thumbsup
Phil.
phatt
Have thanks: 283 times
Re: SPICE software
Postby Brian M » 21 Apr 2011, 03:31
phatt wrote:Hi Brian,
Phil.
Cool... I'll check this one out too. 50 components would probably be fine, because I never try to spice whole circuits. Usually parts of them to see if they work correctly, or to find out why it's not working. I did the math on this tone control I'm working on, and it doesn't really sound like I expected it to.
Brian M
Re: SPICE software
Postby coldcraft » 21 Apr 2011, 16:16
Brian M wrote:I'm more interesting in simulating frequency response of a circuit. If there are variables (like potentiometers) in the circuit it's a pain to set up correctly, and I don't think I've ever seen a result that looked correct when graphed (probably user error).
The variant 5Spice works great for this. There is also a free version you could test drive. http://www.5spice.com/
coldcraft
Has thanked: 42 times
Have thanks: 83 times
Re: SPICE software
Postby Hotrats » 31 May 2011, 09:59
Hotrats
Have thanks: 17 times
Re: SPICE software
Postby electrical » 31 May 2011, 19:22
In my circuits class (I'm studying to be an electrical engineer), we used PSpice. It has frequency sweep capabilities.
electrical
Return to Software Room
