How to make a Vero layout? -on Mac-
If you're running 10.4 or later then the java version of DIY layout creator should run OK.Emanuele wrote:The title says it all, I use almost only vero boards, and I'd like to post some of my ideas...on Mac if possibile..
If you're on 10.3 (like me) or older then it's a bit trickier. I use Illustrator. It's a bit of a pain to start with but once you've got some symbols for the components saved then it's pretty quick.
