BBD SPICE Model
BBD SPICE Model
Postby spacemusicdude » 03 Apr 2015, 19:02
I've built a SPICE model so I can play with clock, bias, and filter circuits for BBD projects. It seems to perform pretty close to a real one, though I have drawn only 8 stages to keep simulation times practical. The biasing and distortion behavior seem pretty close to Panasonic datasheets for 32xx series. Being 8 stages, the delay time is very small, but does visibly change with clock rate as expected. The capacitive load simulates a 3205 (4096 stages), but can be easily adjusted.
For this message the author spacemusicdude has received thanks: 10
287m (28 Nov 2015, 12:33), Dirk_Hendrik (03 Apr 2015, 22:00), Duckman (17 Nov 2015, 01:42), Fender3D (03 Apr 2015, 20:04), FiveseveN (03 Apr 2015, 19:59), Ice-9 (26 Nov 2015, 18:44), marshmellow (12 Apr 2015, 11:18), MC-Sammer (16 Nov 2015, 17:40), mister707 (05 Apr 2015, 05:57), modman (04 Apr 2015, 10:58)
spacemusicdude
Have thanks: 10 times
Re: BBD SPICE Model
Postby Dirk_Hendrik » 03 Apr 2015, 22:00
Where's the Like button when you need one :thumbsup
Has thanked: 255 times
Have thanks: 1028 times
Re: BBD SPICE Model
Postby MC-Sammer » 16 Nov 2015, 18:48
Just doing a little looking into recreating this in LTSpice, and I found a new models for the Transistors
http://people.rit.edu/lffeee/CD4007_SPICE_MODEL.pdf
I'll see if I can get this working, and upload what I get :)
MC-Sammer
Have thanks: 9 times
Return to Software Room
