PCB DESIGN
PCB DESIGN
Postby black03 » 25 Feb 2018, 23:11
hi, a query, to design the pcb, are there some important tips to keep in mind? the ground? the signal of in and out, oscillations, noises,
someone has info to consider before doing a bad pcb?
black03
Re: PCB DESIGN
Postby POTL » 26 Feb 2018, 01:37
Some time ago I clarified the main problems when designing boards, for effect pedals, I asked this question on many forums, the answer was the same, in such simple schemes as analog effects do not worry about problems, there are a number of recommendations, but it is simple:
1) ground, do not allow the appearance of ground loops, I recommend using the board surface as ground, that is, making the earth fill
2) Ground the enclosure, through the input and output sockets or through the wire
3) When creating high-gain distortion, try to arrange the input and output of the circuit as far as possible from each other (this protects against self-oscillation)
POTL
Has thanked: 65 times
Have thanks: 60 times
Re: PCB DESIGN
Postby black03 » 28 Feb 2018, 03:45
POTL wrote:Some time ago I clarified the main problems when designing boards, for effect pedals, I asked this question on many forums, the answer was the same, in such simple schemes as analog effects do not worry about problems, there are a number of recommendations, but it is simple:
You are very kind, thanks for answering and helping me.
black03
Return to Software Room
