2 in/2 out switch wiring question
can anyone explain to me how this is done? the best i can figure is that i can use a 4pdt and millenium bypass 2 plus to have an led. is this the best way to do this or is there some other way? If this is the best route can someone please draw a wiring diagram example or try to explain it to me. i would like to be able to still ground the effect input but i am at a loss to how that portion of the circuit works. i have read all the articles on it that i can find and i understand how the led is turned on, but i do not understand where the "shunt" is wired to.
