PCB Veroboard
Collection of answers to the basic questions of stompbox building.
PCB Veroboard
Postby fishfude » 21 Oct 2014, 21:56
Hi Folks,
Bear with me here: I have an idea for a PCB that would be very hackable, with vias everywhere and let's say sockets. At some point I imagine I might want to break traces and/or jumper them later. Is there a way I could create on a PCB, a point where using a veroboard trace cutter, I could simply make a cut and break the trace?
Has thanked: 42 times
Re: PCB Veroboard
Postby Pyr0 » 05 Nov 2014, 02:01
drill 3 small holes in the track (with pads) where you might want a cut, then just use a vero cutter or drill to cut at the middle hole, if you want to bridge it again, add a jumper between the outer holes.
For this message the author Pyr0 has received thanks:
fishfude (13 Nov 2014, 20:08)
Has thanked: 22 times
Have thanks: 20 times
Return to Stompbox Builder's FAQs & How To's
