1/8(0,125)Watt resistors in 9v pedals?
Postby POTL » 12 Aug 2017, 17:29
Can I use such resistors in pedals?
Or at least it is 1/4 Watt
POTL
Has thanked: 55 times
Have thanks: 52 times
Re: 1/8(0,125)Watt resistors in 9v pedals?
Postby alexradium » 12 Aug 2017, 17:54
sure,Marshall did it,worked fine.
For this message the author alexradium has received thanks:
POTL (12 Aug 2017, 18:05)
alexradium
Has thanked: 51 times
Have thanks: 53 times
Postby POTL » 12 Aug 2017, 18:06
alexradium wrote:sure,Marshall did it,worked fine.
Great
Does this apply to the new Marshall?
POTL
Postby POTL » 12 Aug 2017, 18:10
Also I noticed compact resistors in EQD pedals, as I understand it is also 1/8 watt, am I right?
POTL
Postby ppluis0 » 13 Aug 2017, 02:19
Hi folks,
If we connect a 680 ohms resistor across the contacts of a fresh 9 Volt battery, the dissipation in that resistor is only 119 mW
So, resistors of higher value than 680 ohms dissipate consequently less power than 1/8 W in stompboxes working at 9 Vdc... 8)
For this message the author ppluis0 has received thanks:
deltafred (13 Aug 2017, 12:30)
ppluis0
Has thanked: 34 times
Have thanks: 71 times
Postby POTL » 13 Aug 2017, 08:10
ppluis0 wrote:Hi folks,
This is considered subject to the connection to the network 9 volts.
It turns out that values ​​less than 680m can be used when connecting to the ground or the sound part, the main thing is not to connect directly to the power (half-power again, it does not concern.
I'm right?
POTL
Postby deltafred » 13 Aug 2017, 12:47
POTL wrote:I'm right?
From a power rating point yes you are right.
I would think (without breaking out Kirchoff's Law on all resistors in a pedal) that you can use 1/8W resistors in 99.99% of cases.
There are probably exceptions in some power supply polarity protection circuits. If the safety of your pedal relies upon a low value resistor (+ diode) shunting an incorrect polarity power supply down to a level that does not damage the semiconductor devices then it will be best to calculate the maximum dissipation and add a safety factor.
deltafred
Has thanked: 364 times
Have thanks: 254 times
