I hope this is in the right place to post. I recently purchased the 7 of Dwarves kit from Fuzz Dog. I studied electronics but it was about 100 years ago, and I've forgotten much of it. I'm working to get it back, hence building this kit, but I'm hoping someone can give me a hand with troubleshooting. I have read 'R.G. Keens troubleshooting guide' as per the FuzzDog website, but I'm still struggling. Having built the pedal it's completely dead - no sound at all (not even a buzz).
So far I have:
- Checked all components - 3 times. They're correctly placed and in the right way round.
Cleaned the excess flux off the board
Checked my power supply and grounds are all correct
'Bypassed' the board so check everything between guitar and amp is good - it is (I just connted signal input to out together on the board and got sound fine)
Solder joints all look good - it was something I was pretty good at back at college
I get 9V at the main power in pad on the PCB (where the +ve wire is soldered....first things first right?)
I get 9V both sides of R31
The LED works
I get literally less than 1mV everywhre else - D5 (both sides), R30 etc. For example at V1 of the Voltage Regulator (IC3) I am getting 0.01 mV
I'm sure it's something obvious to you guys so a nudge in the right direction would be really great. This was supposed to be a Christmas present!
Thanks in advance
EDIT: I put a jumper between my main 9V supply and V1, and it sprung into life - however the effect is extremely weak...I can barely hear it?
TG
