From AIWA TP-1011 mic preamp to a standalone pedal...  [schematic]
Postby gilmour_pugliese » 30 Jul 2011, 11:50
Hi, here's the schematic of the TP-1011 (thanks oh7hhi!)... Now I want to isolate the mic preamp section to make a preamp/boost pedal like this:
http://www.treblebooster.net/rpa.html
Is the highlighted portion the right one?
thanks! :applause:
For this message the author gilmour_pugliese has received thanks: 3
modman (13 Apr 2018, 09:50), progulus (15 Mar 2018, 14:52), Wlat (03 May 2014, 16:50)
gilmour_pugliese
Have thanks: 34 times
Re: From AIWA TP-1011 mic preamp to a standalone pedal...
Postby DrNomis » 30 Jul 2011, 12:07
Yeah, I reckon that section of the schematic that you've highlighted looks like the right section, it's hard to be sure exactly which section Ritchie Blackmore actually used, because I've read a few articles where he's being interviewed, and all he said was that he used the preamp of the AIWA TP-1011, still, I reckon that it would make a really interesting subject for a project, don't you think?... :hmmm:
I'm going to download a copy of the schematic and see if I can make a pedal out of it too.... :thumbsup
Has thanked: 123 times
Have thanks: 399 times
Postby gilmour_pugliese » 30 Jul 2011, 12:28
DrNomis wrote:Yeah, I reckon that section of the schematic that you've highlighted looks like the right section, it's hard to be sure exactly which section Ritchie Blackmore actually used, because I've read a few articles where he's being interviewed, and all he said was that he used the preamp of the AIWA TP-1011
Here's my Bible:
http://www.treblebooster.net/mk3.html
The mic preamp seems to be the right section... :mrgreen:
DrNomis wrote:I reckon that it would make a really interesting subject for a project, don't you think?... :hmmm:
oh yesssssssssssssss :popcorn:
Unfortunately I haven't a solid electronic knowledge, but if someone helps me to adapt the preamp into a pedal I'll draw a vero layout... :block:
gilmour_pugliese
Postby RnFR » 30 Jul 2011, 12:32
I seriously doubt that BSM used that whole highlighted portion in their pedal. I'm betting it's something much simpler. personally, I wouldn't trust anything from a company that sells gooped single tranny boosters for $300, but by all means, make your own version. I would think the first stage or two would be fine, but the proper voltage is probably necessary to build it without it sounding like fuzz pedal.
Has thanked: 150 times
Have thanks: 174 times
Postby DrNomis » 30 Jul 2011, 12:39
Here's my Bible:
Well, I'm happy to give you some help with it mate, what I'll do is I'll draw just the hilighted section on a bit of A4 printer paper, scan it into my computer, and I'll get it posted in this thread, how about that?, I happen to be a bit of a Deep Purple fan myself.... :thumbsup
Postby DrNomis » 30 Jul 2011, 12:43
RnFR wrote:I seriously doubt that BSM used that whole highlighted portion in their pedal. I'm betting it's something much simpler. personally, I wouldn't trust anything from a company that sells gooped single tranny boosters for $300, but by all means, make your own version. I would think the first stage or two would be fine, but the proper voltage is probably necessary to build it without it sounding like fuzz pedal.
Well, we can always tweak it till we get it nailed anyway..... :thumbsup
Postby gilmour_pugliese » 30 Jul 2011, 12:44
RnFR wrote:I wouldn't trust anything from a company that sells gooped single tranny boosters for $300, but by all means, make your own version.
I think the same thing :lol:
RnFR wrote:I would think the first stage or two would be fine, but the proper voltage is probably necessary to build it without it sounding like fuzz pedal.
the BSM is powered at 9v... but IMHO a 18-24v gives more headroom and less fizziness :popcorn:
Now I'm comparing the Aiwa preamp with some treble boosters (JHS, Rangemaster, etc...) to find some similarities and then I'll reshape the original 4 stages to one or two :horsey:
gilmour_pugliese
Postby DrNomis » 30 Jul 2011, 14:16
Okay, I've made a print out of the original schematic and now I'm making a drawing of just the mic preamp and associated circuitry, stay tuned.... :thumbsup
For this message the author DrNomis has received thanks:
gilmour_pugliese (30 Jul 2011, 14:24)
Postby oh7hhi » 30 Jul 2011, 14:39
I'm not sure how that "source"-switch works, but could it be that signal goes to line-out jack straight after the first 2SC372 (via 10k resistor and 50k pot) if the "source"-switch is in another position?
oh7hhi
Has thanked: 36 times
Have thanks: 12 times
Postby analogguru » 30 Jul 2011, 14:50
RnFR wrote:Personally, I wouldn't trust anything from a company that sells gooped single tranny boosters for $300, but by all means, make your own version. I would think the first stage or two would be fine, but the proper voltage is probably necessary to build it without it sounding like fuzz pedal.
How true. Astonishing, which s**t people buy when it is only conducted with a big name. I am sitting and wondering what this standard circuit could do specially, or if it wouldn´t be better to build an Colorsound Overdriver instead.
Have thanks: 116 times
Postby DrNomis » 30 Jul 2011, 14:58
Unfortunately that's the way it goes, you watch, these 2SC series Si transistors will attain the mythical status that Ge transistors attained.... :lol:
Welcome back to FSB Analogguru, haven't seen you around for a while.... :thumbsup
Postby DrNomis » 30 Jul 2011, 15:00
oh7hhi wrote:I'm not sure how that "source"-switch works, but could it be that signal goes to line-out jack straight after the first 2SC372 (via 10k resistor and 50k pot) if the "source"-switch is in another position?
In my drawing, I've decided to eliminate all components and connections not used in mic preamp mode.... :D
Postby gilmour_pugliese » 30 Jul 2011, 15:06
first of all, thanks for your contribution! :popcorn:
DrNomis wrote:Unfortunately that's the way it goes, you watch, these 2SC series Si transistors will attain the mythical status that Ge transistors attained.... :lol:
could I replace these super mojo trannies with a LM3046 without some Texan problems? :horsey: :mrgreen:
DrNomis wrote:Welcome back to FSB Analoguru, haven't seen you around for a while.... :thumbsup
+1
gilmour_pugliese
Postby DrNomis » 30 Jul 2011, 15:45
gilmour_pugliese wrote:first of all, thanks for your contribution! :popcorn:
+1
I really can't see why you couldn't replace all transistors with an LM3046, as long as there's two transistors with their emitters tied together in the schematic.... :thumbsup
By the way, here's a scan of my schematic diagram, I tried to include all part values with them.... :thumbsup
Postby oh7hhi » 30 Jul 2011, 16:29
It's the MOJO again :wink: ...
oh7hhi
Postby roseblood11 » 30 Jul 2011, 16:41
DrNomis wrote:could I replace these super mojo trannies with a LM3046 without some Texan problems?
Sure you can, but you will get a letter from Lance K. :D
Maybe you´ll end up as pen-friends...
roseblood11
Has thanked: 348 times
Have thanks: 310 times
Postby gilmour_pugliese » 30 Jul 2011, 17:15
:slap:
:popcorn:
gilmour_pugliese
Postby gilmour_pugliese » 30 Jul 2011, 17:37
analogguru wrote:I am sitting and wondering what this standard circuit could do specially, or if it wouldn´t be better to build an Colorsound Overdriver instead.
Looking both the AG scheme and Overdriver there're some similarities... I'm in doubt, 'cause I already own a Powerboost :scratch:
gilmour_pugliese
Postby DrNomis » 30 Jul 2011, 18:13
I wouldn't be surprised if the Coloursound Overdriver was based on the circuit, all that would have had to be done was add the bass/treble tone controls and change the resistor on the second transistor's emitter to a 10k pot, and voila!....instant Overdriver.... :hmmm:
Postby gilmour_pugliese » 30 Jul 2011, 18:38
here's the comparison :popcorn:
gilmour_pugliese
Next
Users browsing this forum: BuryMeInSmoke and 2 guests
