Hi, I'm looking to see if I can track down any of Jake's designs. I've built a Blue Magic and I like it, and I'm ready to start on and have heard clips of the SuperNova. (Both of those from GGG)
I've also got the Earthshine package (unsure of the origin of this one, but same layout as the above two)
Are there any more? Google has not been my friend in this case.
Is Jake still active in the stompboxes community? Last I hard he was working as a psychologist (there's a fine line, really! )
Minor7th
Jake Nagy effects?
- RLBJR65
Killer Bee;
"The Killer Bee uses a BS170 MOSFET to overdrive four J201 JFETS to produce a wide range of overdrive/distortion sounds." http://www.mediafire.com/?89lmlkv0wnt
X-FET;
"The X-FET is a very low to pretty high gain, tube-ish, distortion pedal that relies on a MOSFET(BS170) to overdrive two JFETs (J201)." http://www.mediafire.com/?3onnmdwbigx
Blue Magic;
"Blue Magic is a very low to medium grit, tube-like overdrive pedal that is based on a MOSFET (BS170) pushing a JFET (J201) into distortion." http://www.generalguitargadgets.com/diagrams/bmagic.pdf
Earthshine;
"Earthshine is medium to very high gain, tube-ish, distortion pedal that relies on a MOSFET (BS170) to overdrive three JFETs (J201)." http://www.mediafire.com/?3yrylywf9g2
Supa Nova;
"The Supa Nova is a very low to pretty high gain, tube-ish, distortion pedal that relies on a MOSFET (BS170) to overdrive two JFETs (J201)." http://www.generalguitargadgets.com/dia ... panova.pdf
Edit; added links to the other projects.
X-FET;
Blue Magic;
Earthshine;
Supa Nova;
