Alembic F2B FET Version with Balanced Output
DarkRain
Has thanked: 13 times
Been thanked: 181 times
Post by DarkRain »
Had a little time for a friend request (he is a bass player and wanted a little preamp for small / medium gigs). I've used a FET version of the Alembic F2B bass preamp and attached an balanced output - for maximum headroom the pedal will use AC power supply (9V AC) - the OA is using +/- power supply.
This is the last version of the schematic and the first version of board. Build it ... put it on oscilloscope, everything looks good (i don't have a bass guitar right now for some tests but already spoked to a friend of mine to come and give it a try).
SCH: https://dl.dropboxusercontent.com/u/152 ... 2b_fet.sch
BRD: https://dl.dropboxusercontent.com/u/152 ... 2b_fet.brd
If you would like to build it you are more then welcomed.
Best regards,
Gabriel Tudoran
Analog Sound
PS: It works wonderful with guitar also.
Godebut
Post by Godebut »
I just get a shedload of text when hitting the schematic?
DarkRain
Post by DarkRain »
Hhihiih :D just right-click and save link as (or save file as) - that is what is inside an eagle file. That is correct, just save them as files and should be OK (web browsers doesn't recognize the MIME Type)
Best regards,
Gabriel Tudoran
Analog Sound
Godebut wrote:I just get a shedload of text when hitting the schematic?
Godebut
Post by Godebut »
Thanx
DarkRain
Post by DarkRain »
No problem,
If you will build it drop me an opinion about it.
Best regards,
Gabriel Tudoran
Analog Sound
DarkRain
Post by DarkRain »
Tow pictures with the prototype and ... a sound sample with various settings directly into sound card.
Please don't throw with tomatoes .... i'm just a guitar player :D
Best regards,
Gabriel Tudoran
Analog Sound
DarkRain
Post by DarkRain »
Hey guys, some recordings made by a friend of mine who is a bass player (not like me :D ). The EQ was at 12 o'clock and in the name of the clips you will find the Gain and Volume settings (ex G9 V8 is Gain at 9 o'clock and Volume at 8 o'clock).
There are also 3 clips recorded with the bass directly into sound card and one with Sansamp BDDI and one with M80 from Mxr. The clips ware recorded for comparison.
Enjoy and any comments are greatly appreciated.
Best regards,
Gabriel Tudoran
Analog Sound
deltafred
Has thanked: 813 times
Been thanked: 306 times
Post by deltafred »
Sounds pretty good.
I have saved the .sch and .brd files but Eagle won't open either, it gives an errors of "Invalid data in file /home/...." I have no experience of using Eagle so maybe it is something I am doing wrong.
Any chance of putting up a schematic as a jpg, gif or png file?
The G
Grease Monkey
Has thanked: 408 times
Been thanked: 285 times
Post by The G »
It opens all right in Eagle 6.4.0.
This PCB image has 300dpi.
deltafred
Post by deltafred »
Thanks for the pictures ggedamed.
I was trying to use Version 5.12.0 for Linux from the Ubuntu Software Centre, which is probably well out of date.
I should get the latest version from the Eagle website, but I really don't need another application to learn.
DarkRain
Post by DarkRain »
The schematic is not full, i will post it ASAP (the supply and xlr output is not in there).
Best regards,
Gabriel Tudoran
Analog Sound
PS: This is the link with PDF with full schematic https://dl.dropboxusercontent.com/u/152 ... t_full.pdf
deltafred wrote:Thanks for the pictures ggedamed.
deltafred
Post by deltafred »
I deleted my old version of Eagle and downloaded the latest, 6.5.0 (Light), and it works fine now. Thanks guys.
What voltage AC are you using DarkRain?
DarkRain
Post by DarkRain »
Anything between 6 and 10v would do ... is not critical.
I would recommend not to exceed 10v as it will exceed opamp voltage (30v - +/- 15v)
Best regards,
Gabriel Tudoran
Analog Sound
deltafred wrote:I deleted my old version of Eagle and downloaded the latest, 6.5.0 (Light), and it works fine now. Thanks guys.
Duckman
Has thanked: 320 times
Been thanked: 134 times
Post by Duckman »
Dropbox links are dead :(
Please, can somebody share a new valid link, or pdf of the complete project?
DarkRain
Post by DarkRain »
Duckman wrote:Dropbox links are dead :(
@Duckman - There you go bro, both BRD and SCH eagle files
Duckman
Post by Duckman »
Thanks a lot!
This is a little embarrassing :oops: but I don't use eagle.
If you have the pdf, you save me from install eagle just to see one schemo :hug:
If you don't, I downloaded the codes, any way and I'll wait a little more and then... reinstall eagle! :slap: :lol:
DarkRain
Post by DarkRain »
that is not a problem. I will make you a pdf doc tomorow with the schematic and a ready to print pcb ;)
Duckman
Post by Duckman »
Tanks!! :applause:
I just need the schematics, but a verified PCB always help to check and debug. :thumbsup
Thanks again! :hug:
WarrenPease
Post by WarrenPease »
Hi, Gabriel.
Thanks for all the cool stuff you have posted for our benefit. :thumbsup
What value resistor do you use in between the caps in the power supply, (R6, R7, R8, R9)?
Something like 120R?
DarkRain
Post by DarkRain »
@WarrenPease: anything between 100 and 150 ohm will do just fine :)
Regards,
Gabriel
