Vertex Boost Workalike
Postby mmolteratx » 23 Jul 2014, 08:03
Saw this in a thread on TGP, and thought it was a worthwhile enough idea. Knocked up this workalike and breadboarded it in about 10 minutes. :lol: Expression pedal wiring will probably depend on what type you wind up using. As shown, it should work with a Boss FV500L, though I can't say for sure since I don't currently have any expression pedals on hand and can't find a schem for any of the commonly used ones.
No layout, as I didn't care enough to go past the initial design phase. I'm sure someone can knock up a vero layout if enough people are interested. Works well enough as a boost alone, and has up to 20dB of gain (vs 16dB for the Vertex), so feel free to also omit the expression out if you find it useless. Can also just use true bypass to make into into a Landau Boost workalike. :lol:
For this message the author mmolteratx has received thanks: 6
atreidesheir (24 Jul 2014, 00:02), IvIark (23 Jul 2014, 11:08), Manfred (11 Mar 2015, 10:26), micromegas (11 Aug 2014, 18:45), okgb (06 Nov 2016, 17:14), SonicDaeath (02 Sep 2014, 01:40)
mmolteratx
Has thanked: 103 times
Have thanks: 621 times
Re: Vertex Boost Workalike
Postby harmaes » 10 Mar 2015, 20:41
How would I add an expression pedal input with a switched stereo Jack for my Klon clone?
Replacing the volume pot with the expression pedal pot is easy. I want to have the expression pedal control the range set by the position of the volume knob and off. Would that be possible?
harmaes
Have thanks: 3 times
Postby Chugs » 03 May 2015, 11:36
Interesting gain control setup. How could you add a fixed low pass filter to IC1A, at say 7200z, that did not vary as you changed the amount of gain?
Chugs
Has thanked: 59 times
Have thanks: 48 times
Postby harmaes » 11 May 2015, 09:25
Can someone create a vero layout for this? Thanks!
harmaes
Postby soulsonic » 11 May 2015, 16:23
does it HAVE to be vero? I could do a really nice PCB layout easily enough...
It's really not hard to etch PCBs at home. I think people need to get back into this...it's a much more rewarding DIY experience.
Has thanked: 53 times
Have thanks: 263 times
Postby lolbou » 11 May 2015, 21:09
soulsonic wrote:It's really not hard to etch PCBs at home. I think people need to get back into this...it's a much more rewarding DIY experience.
+1!!
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lolbou
Has thanked: 346 times
Have thanks: 234 times
Postby mmolteratx » 11 May 2015, 21:24
FWIW, I wouldn't recommend building this one. I can do a redesign, but as is, it's kind of hissy and I'm not a huge fan of the overall performance.
mmolteratx
Postby okgb » 06 Nov 2016, 17:17
This is the one Robben Ford endorses ? wonder how a hissy pedal could make it to market !
okgb
Has thanked: 185 times
Have thanks: 41 times
Users browsing this forum: pwn57ar, temol and 5 guests
