possible on-the-fly wah to (quasi) volume switching idea
Postby pinkjimiphoton » 08 Apr 2017, 03:20
so i was looking at my wah wishing it would do volume too. and i thought about it for about 40 seconds and realized now that 4pdt switches are available, common, and relatively cheap, it could be done with a single stomp of a 4pdt wired as shown in the attachment.
it is an experiment only, i haven't tried it yet, but it SHOULD work, at least to a point...
caveats: it will likely not have a great volume sweep and compromise may need to be found between the wah and volume options cuzza the amount of rotation of the pot by the pedal.. ie, where the wah sounds best may not be best for optimal volume
it may not go all the way "down" to off
it may not go all the way "up" to full blast
you MAY be able to add tapering trimmers to the circuit to make it work a little better on the volume side.... by soldering in a couple trimmers, you can likely get it to go "all the way off"... probably not all the way on.
may be worth adding trimmers to the wah side as well, so you can find a decent compromise with the sweep for both options
may need (a) pull down resistor(s) so it doesn't "pop"
remember, it HAS NOT BEEN TRIED BY ME YET.... so no idea if it's gonna work as i expect. the layout below is not verified,
but if ya follow the connections it should most definitely work, tho how well? good question.
you may wanna go with a joe gagan 500k smooth pot, as it will likely improve the sweep of both wah and volume... like everything, it's a compromise
i haven't figured out how to add an LED. thinking may be better to do the switching electronically, but way above my present paygrade.
worst case scenario, you'll have to rewire your wah. nothing is irreversible with this mod.
hoping it works, and someone can find some benefit from it.
i plan on doing my main wah tomorrow afternoon and seeing if i can live with it.
ANYWAYS....
pinkjimiphoton
Has thanked: 229 times
Have thanks: 347 times
Re: possible on-the-fly wah to (quasi) volume switching idea
Postby pinkjimiphoton » 09 Apr 2017, 02:30
son of a bitch!!! ;) it works!!! BUT it works like a jap wah, the wah and volume functions are opposite... heel down is full volume, toe down is ALMOST all the way down. wah works normally, NO POPS!!!
i will send ya a new layout when i'm done cuz i made this a little unclear before... and i added a 2.2n cap to it too to keep the treble suck down in volume mode, but it actually works!!!
pinkjimiphoton
Postby caspercody » 09 Apr 2017, 03:13
Thanks for this idea, and getting it to work.
For this message the author caspercody has received thanks:
pinkjimiphoton (09 Apr 2017, 04:09)
caspercody
Has thanked: 30 times
Have thanks: 43 times
Postby pinkjimiphoton » 09 Apr 2017, 03:15
here ya go!! verified layout. i used the color code in my ancient vox wah, but should be easy enough to do with any other kinds.
in a cheap ass pyle pro plastic wah, i think the volume will work normally.. their pot is actually backward from how we normally think of it being.
but anyways... it does work. and well!! surprisingly well!! but like i said, it's like a 70's japanese wah, the volume and wah functions are opposite. i kinda diggit. i may do it to my main wah, then i can ditch a volume pedal on my board!
anyways...
pinkjimiphoton
Users browsing this forum: akc2009 and 2 guests
