ParaBoost - Parametric EQ with MosFET booster
Postby DarkRain » 11 May 2017, 08:30
Hello dear fellas,
Long time no posts. I'm working on a new project called ParaBoost which is basically a parametric EQ and a MosFET booster.
The order is EQ => Boost because i wanted to have the tone shaped before it enters the boost section (input of the EQ section is buffered with a classical MOSFET buffer).
Here you have some measurements along with the first planted PCB
- lowest freq - highest Q - boost / cut
- highest freq - highest Q - boost / cut
- lowest / mid (freq. pot at middle) / highest - highest Q - cut
- lowest / mid (freq. pot at middle) / highest - highest Q - boost
Soon I will post the final schematic.
Regards,
DeX
For this message the author DarkRain has received thanks: 4
atreidesheir (21 May 2017, 04:22), auden100 (28 May 2017, 04:21), Chugs (12 May 2017, 18:59), GypsyDay (06 Jun 2017, 05:13)
DarkRain
Has thanked: 13 times
Have thanks: 199 times
