DIY a select expression pedal
Postby slowre » 23 May 2017, 14:59
I would like to know if this diagram is correct
Is there a problem?
https://drive.google.com/open?id=0B9mWEilSMt9YN29rM2lEVjlXOGc
slowre
Re: DIY a select expression pedal
Postby poiureza » 29 May 2017, 15:50
Assuming the pin numbering at the the input block is just a typo (321 instead of 123), this should work.
There's a risk it will make a popping sound when you switch though.
poiureza
Has thanked: 15 times
Have thanks: 10 times
