JFET boost
JFET boost
Postby Nocentelli » 08 Oct 2017, 20:17
A simple boost/preamp circuit I put together recently. The JFET starts to clip in a pleasingly smooth manner if you really dig in so the gain control allows you to set how hard you need to play to make this happen. The simple active two band EQ gives a nice range of tones for not many parts.
For this message the author Nocentelli has received thanks: 14
blackbunny (09 Oct 2017, 03:27), Cub (08 Oct 2017, 21:32), dv8r601 (11 Oct 2017, 04:22), Groovenut (08 Oct 2017, 22:12), HENK (09 Oct 2017, 12:10), Intripped (09 Oct 2017, 09:03), Manfred (08 Oct 2017, 21:36), okgb (09 Oct 2017, 16:33), rcustoms (09 Oct 2017, 01:19), Zokk (09 Oct 2017, 12:20) and 4 more users
Nocentelli
Has thanked: 776 times
Have thanks: 795 times
Re: JFET boost
Postby roseblood11 » 09 Oct 2017, 16:38
Nice. Do you see an advantage of this circuit over the Boss FA-1? The parts count is similar.
roseblood11
Has thanked: 312 times
Have thanks: 298 times
Re: JFET boost
Postby Nocentelli » 09 Oct 2017, 18:14
I think the JFET gives a certain je ne sais quoi that an op amp booster doesn't, i.e. mainly a little bit of distortion/compression on the edge of the notes when you hit the guitar hard. Apart from that, I had one single decent spec J201 left in my stash of through-holes that I wanted to make into something useful :lol:
Since posting the schematic, I have attempted to design a small and efficient veroboard layout and have (re)discovered that single op amps are terrible for efficient use of space. I've done another schematic for a transistor-based baxandall stage, which should be much easier to lay out nice and small. I'll post the new schem when I'm happy it works properly and sounds as good as the one above.
For this message the author Nocentelli has received thanks: 2
rbstep (14 Oct 2017, 00:08), roseblood11 (10 Oct 2017, 19:30)
Nocentelli
Re: JFET boost
Postby Nocentelli » 14 Oct 2017, 12:08
For this message the author Nocentelli has received thanks: 5
287m (14 Oct 2017, 14:56), dv8r601 (17 Oct 2017, 03:11), Intripped (14 Oct 2017, 13:50), Manfred (14 Oct 2017, 16:08), mirosol (14 Oct 2017, 14:25)
Nocentelli
cron
