Analogman Chorus Schematic + Mods
Postby POTL » 18 Oct 2017, 14:19
Hello
I'm interested in the Analogman Chorus circuit - I know that this is an EHX Small Clone circuit from the Tone Pad site, but it has minor changes, who is aware of these changes, what has Mike changed?
Also I'm interested in the following fashion
1) Mix - in the left position it is completely pure signal, in the right position it is a chorus (a variant with three modes, clean-chorus-vibrato is not interesting)
I understand that this should be in the mix section, R5 / R21 but how is it better to implement it?
As in the Boss CE-2B?
2) 2) Delay Time
As I understand it, the only option is to replace the R32 with a fixed resistor and a 100K potentiometer in the series with it?
POTL
Has thanked: 65 times
Have thanks: 60 times
Re: Analogman Chorus Schematic + Mods
Postby The Rotagilla » 18 Oct 2017, 20:34
FWIW, Analogman has stated that the original EH schematic (and ones that were based on it) contained errors. I've always meant to get around to tracing one out but life usually has other plans. Also keep in mind that he swore the King of Tone and Bigfoot/Fargen JW-40 drive circuit were original designs. :roll:
For this message the author The Rotagilla has received thanks:
Nocentelli (20 Oct 2017, 08:14)
The Rotagilla
Have thanks: 57 times
Postby gena_p1 » 15 Dec 2017, 11:55
we've traced several years ago.
A.M. chorus 97% == tonepad small clone, except 2-3 values
gena_p1
Has thanked: 27 times
Have thanks: 19 times
Postby POTL » 16 Dec 2017, 02:50
gena_p1 wrote:we've traced several years ago.
Hi
I'm aware, but I have not found any exact changes anywhere.
Once you decide to stop releasing your chorus, maybe you'll share the differences in the components?
In this thread or in private messages.
I have a couple of assumptions about ceramic capacitors (1 changed value, 1 is missing in the circuit), but this is only an assumption.
POTL
