Tube DI?
Barcode
Been thanked: 32 times
Post by Barcode »
anyone seen a reasonable DIY project for a tube dirven direct box, hopefully one that runs on low voltage (like a 12AX7 tube or something like that)?
Has thanked: 232 times
Been thanked: 888 times
BK Butler patent 5,343,159 of any use??
http://www.pat2pdf.org/patents/pat5343159.pdf
Although the real novelty of this "invention" is unclear to me. :roll:
Has thanked: 183 times
Been thanked: 468 times
I'm skeptical about a low voltage tube circuit sounding very good as a DI. They're best for overdrives. Though, the Presonus Blue Tube I have has a low voltage tube circuit in it and it sounds pretty good as a DI, BUT the tube in the Blue Tube really isn't doing any of the DI-ing work, it's more there to dial "hair" into the signal.
Sari
Has thanked: 26 times
Post by Sari »
The Tube's role in BK Butler SS-Tube hybrid is to effect the OA's feed back in real time. From the brief glance I gave the file, I gathered that Butler idea is to impose the "tube dynamics" on the OA.
I should probably read through this doc more thoroughly.
The Idea was not new but BK butler did ad protective measures to the hybrid stage so that it could work when the tube is malfunctioning
