German DIY distortion building instruction from 1985
Postby Manfred » 15 May 2018, 22:50
While recently clearing out I found this copy of an DIY-Instruction from the last millennium. :D
Funkschau was an electronics magazin puplished in Germany.
The article dealt with the pre and post frequency filtering about the clipping stage.
I think the circuit is great for making trials to this topic.
The component drawing is blurred and the solder side drawing got a lack of sharpness, so I had to create a new layout.
There are two diffrences between the layout and the schematic, therefore the schematic had to be corrected.
Distortion85_PCB_ComponetSide.pdf
Distortion85_PCB_SolderSide.pdf
Distortion85_PCB_SolderSideMirrored.pdf
For this message the author Manfred has received thanks: 9
287m (16 May 2018, 14:21), d312a (16 May 2018, 03:51), graeme (16 May 2018, 06:27), HENK (17 May 2018, 14:07), karul (17 May 2018, 22:46), krome_magnon (16 May 2018, 19:07), nickthemen (16 May 2018, 10:23), OC26 (17 May 2018, 11:51), sixthfloor (16 May 2018, 09:57)
Manfred
Has thanked: 901 times
Have thanks: 427 times
Users browsing this forum: jonfoote and 2 guests
