Single Pot for Univibe rate (GEOFEX)
Postby Diodes3Ground » 26 Sep 2018, 01:55
I came across this while searching up information on univibe circuits:
http://www.geofex.com/circuits/ldrlfo.htm
Has anyone ever tried doing this when building a univibe or such? I'm designing my own vibe right now, and the ability to use a single pot and with an opto coupler instead of a hard to find double gang 100kC pot is very appealing. Problem is, I have a bunch of questions about implementing it (ie. ideal part values, what D1 and Q1 should be, etc.).
Anyone got any tips? I think this could be used to achieve slower rate speeds and make it easier to add an expression jack, so I really hope some of you are able to help out. Thanks!
Diodes3Ground
Re: Single Pot for Univibe rate (GEOFEX)
Postby Yazoo55 » 27 Sep 2018, 13:53
I built the Univibe in a Wah shell project. An option for this project includes an optocoupler to avoid using a dual gang pot. The project file for this might be worth reading:
http://www.geofex.com/FX_images/UVICS-3%20Project%20File-3.pdf
For this message the author Yazoo55 has received thanks:
Diodes3Ground (04 Oct 2018, 04:44)
Yazoo55
Have thanks: 9 times
Postby Diodes3Ground » 04 Oct 2018, 04:45
Cool, I'll check it out. Did you build it with the single pot option? If so, how well does it work?
Diodes3Ground
Postby Yazoo55 » 04 Oct 2018, 11:00
Yes, I managed to get the Vactrol from Banzai in Germany. It works fine, a really good project.
Yazoo55
Users browsing this forum: ZKS and 3 guests
