I would like to try to build a pedal based on the EQD Speaker cranker... which is based on the good old Electra Distorsion.
I have already built a SPeaker Cranker, following this layout : http://tagboardeffects.blogspot.com/201 ... anker.html
It works fine, but i want to adjust some values, and try some other component for experimentation purposes.
I enjoy the Speaker Cranker, but i want a more bass friendly pedal (so i upped the input & output caps values).
I want to get rid of the Gain knob - so i have read that i can also get rid of the first 100µF capacitor. I have chosen a fixed value of 3.3K, which should bring me close to half-way of the 5K gain pot, roughly : am i correct ?
I will socket the diodes, and also the transistor, o try with either a 2N3904 or a MPSA13.
My questions are both :
- Is my schematic correct, or is there any eror (it's among my first times using a veroboard
- Given that i use a 25V electrolytic capacitor, could this circuit run at 18V ? If not, why (which components would not be 18V compatible ? The transistors ?)
Thank you in advance
