I may have posted this before but My searching sucks soo...
I made 2 neutron pcb's but they seemed really small. I did do a 1 to 1 ratio when I printed them so I thought I was okay.
But I now noticed that the holes for many parts are way to close together for regular sized parts like the caps and opamps. Not to mention if I am going to use vactrols..
So my question to anybody who built this, is this supposed to be a very small board? All of RG's boards look very small comared to GG or tonepad or others..Are there smaller parts that are NOT surface mount that I might be aware of?
Again, I made sure to do a 1 to 1 ratio print, and my laser printer is a very nice color Brother laser printer so, I thinnk or thought I was doing this right.
I want to build a few but I dont want to sit there and play with resizing this thing to get it right. I am making a lovetone clona and that too seemed a little small but everything is fitting...
Any help and what ratio should I try would be greatly appreciated!
RG Keen Neutron PCB Question...
- chicago_mike
Skyline FX 2013
i've had some trouble in the past with printing other people's layouts too. The solution for me is usually just trail and error. I print out the design on a couple of normal sheets of paper and compare the holes with components that i have lying around. What works best for me is using an opamp socket as a reference. or if the there is no opamp on the board and the board was made with something like diy layout creator than i check if the holes that are spaced closest on the board are 2.54 mm apart. Or if all else fails i just check with the datasheet of a part that's used on the layout and i check the dimensions there and then use that as a reference.
but usually i just look for pdf files of layouts because they preserve the aspect ratio the best.
good luck,
Thomas
good luck,
Thomas
All of R.G.'s boards are intended for normal sized components. I asked him instead of posting on some forums, and he told me.chicago_mike wrote: So my question to anybody who built this, is this supposed to be a very small board? All of RG's boards look very small comared to GG or tonepad or others..Are there smaller parts that are NOT surface mount that I might be aware of?
Printers and printing is not an exact one-to-one solution. Each printer/program may do it a bit differently. As noted, PDF is much better about this than other solutions, and that's why I went to PDF for my layouts years ago. But even PDF is not perfect and the printer itself may scale it a bit in either X or Y or both.
What you do is to print one on paper, then adjust your X and Y scaling until things come out the correct size, then print on your photo film or PNP.
On all of my layouts, the width between 1/4W resistor leads is 0.400" if you can't find an IC pattern, like on the Neovibe. On the Neutron, proper scaling is when the distance between pin 1 and pin 4 on a DIP-8 package is 0.300" and the distance between pin 1 and pin 8 is also 0.300".
Mess with it on paper, get the scale right, then go print to your expensive medium.
