Page 8 of 12
Re: Fodera, Sadowsky, aguilar, and other preamps
Posted: 11 Nov 2012, 20:40
by bajaman
hello Immo
Sorry about the dark grey - I was trying to get the best resolution artwork for under the 1M posting limit
I think I tried posting the gerber files as .txt (and many other formats)
I will try again and see.
Steve
Posted: 11 Nov 2012, 20:49
by bajaman
OKAY
I tried to upload the gerber files as *.txt and got the message that txt files are NOT allowed.
I give up
Posted: 11 Nov 2012, 20:54
by bajaman
the gif file as requested
Posted: 11 Nov 2012, 22:19
by lietuvis
bajaman wrote:OKAY
I give up
Hi Bajaman you can try to upload a zip file, previously I was able to do so. right click on mouse then compress file or a few files on mac os, something similar would be in windows, name it whatever you want and upload if its under allowed size to forum
Posted: 11 Nov 2012, 23:22
by bajaman
Okay - thanks for the suggestion lietuvis
Here is a zip file containing the gerber files for both SMD and through hole boards
They are both together, but if you know how to use gerber files you should now how to edit them to suit your chosen format
Posted: 17 Nov 2012, 05:53
by bajaman
RE: BAJA three band active bass preamp:
Here is a more friendly component value schematic for the through hole board layout.
I very much doubt that you would hear any difference to the 051112 schematic previously posted in this thread, but I am sure you will find the components much easier to find.
You can use either the LF442 or TL062 (both are equivalent bifet input low current drain op amps for extended battery life
I just finished populating a through hole board with these component values - it will be a wee while before I can install it in the Jazz bass I am putting together though - I have to make the body first
I already have the neck, machine heads, pickguard, control plate and pick ups (neodymium button magnet and steel pole piece design) sorted, so won't be too long before I can play it
Posted: 17 Nov 2012, 06:21
by bajaman
- Baja three band active bass preamp through hole board 171112 .gif (70.47 KiB) Viewed 9957 times
here is a quick scan of the completed PCB
missing capacitor (470n) is smd on rear of board
NO noisy carbon comp capacitors fitted
Posted: 17 Nov 2012, 10:00
by alexradium
this is cool,what are the center frequencies for each band?
I'd like to know if there is an existing board with fixed B and T and parametric mids all in one,otherwise i could try to design it myself.
That with a 20dB boost would be the end of all pres.
Posted: 17 Nov 2012, 10:11
by bajaman
look back in the thread
- see the graphs
HINT: halfway down page 5
Way too much boost
Posted: 17 Nov 2012, 10:37
by alexradium
ok thank you
Posted: 17 Nov 2012, 16:57
by Duckman
bajaman wrote:Baja three band active bass preamp through hole board 171112 .gif
Looks really beautiful! Baja, you´re a master!
Re: Fodera, Sadowsky, aguilar, and other bass preamps
Posted: 04 Dec 2012, 01:54
by rcustoms
my contribution
a complete project on the yamaha's type preamplifier founded in many brands,who cloned this circuit
I hope you enjoy
Posted: 04 Dec 2012, 02:10
by rcustoms
another ,peavey cirrus bass
- cirrus bass.bmp (897.25 KiB) Viewed 9880 times
- cirrus bass.bmp2.bmp (898.3 KiB) Viewed 9880 times
Posted: 18 Dec 2012, 01:39
by ezugaru
bajaman wrote:RE: BAJA three band active bass preamp:
Hi bajaman, there is no C12 right? it jumps from C11 to C13, greethings!
Posted: 18 Dec 2012, 01:45
by bajaman
correct
Posted: 17 Feb 2013, 23:01
by B3ar
Hidden tracks on SMD are a pain. And it's always a little odd to trace a partially populated board. SoI'm pretty much giving up on this, the active circuit from my 4 string Dearmond Pilot pro. I'm just gonna assume standard BF Fender-style TMB unless I get a bug to follow through on the trace.
The external connections are on the PDF.
Posted: 18 Feb 2013, 06:53
by alexradium
[quotes="B3ar"]Hidden tracks on SMD are a pain. And it's always a little odd to trace a partially populated board. SoI'm pretty much giving up on this, the active circuit from my 4 string Dearmond Pilot pro. I'm just gonna assume standard BF Fender-style TMB unless I get a bug to follow through on the trace.
The external connections are on the PDF.[/quote]
This is the same Board on the Cort gb75 i had
I did tracing and its all based on gyrators
Posted: 18 Feb 2013, 13:36
by B3ar
alexradium wrote:[quotes="B3ar"]Hidden tracks on SMD are a pain. And it's always a little odd to trace a partially populated board. SoI'm pretty much giving up on this, the active circuit from my 4 string Dearmond Pilot pro. I'm just gonna assume standard BF Fender-style TMB unless I get a bug to follow through on the trace.
I did tracing and its all based on gyrators[/quote]
You know, if I had thought about that, I might have started to look at Cort as it's Korean made. Thanks for saving me the effort on this.
Posted: 19 Feb 2013, 02:40
by rcustoms
B3ar wrote:Hidden tracks on SMD are a pain. And it's always a little odd to trace a partially populated board. SoI'm pretty much giving up on this, the active circuit from my 4 string Dearmond Pilot pro. I'm just gonna assume standard BF Fender-style TMB unless I get a bug to follow through on the trace.
ok folks ,let me help ,i been working on this version of the circuit and has two additional trimmers and a little few more components.i trace everything and this is my work,not checked, but I think together we can finish.
I made this PCB with no SMD components
Posted: 20 Feb 2013, 03:55
by rcustoms
wiring and trimmers func.
