Converting trem lune to operate on jfet variable resistor?
- briggs
Anyone got any ideas towards converting the Tremulus Lune to operate on a FET setup as a variable resistor rather than requiring the fairly expensive optocoupler?
This has been bugging me so much! I just can't figure this one out - I've tried all sorts of setups but the correct one is avoiding me like the plague!
Lune info is here: http://www.commonsound.com/kits/doku.ph ... d:tremulus
- briggs
- bajaman
- Has thanked: 596 times
- Been thanked: 2061 times
Its only money - opto has much better linearity
- modman
- a d m i n
- Has thanked: 4411 times
- Been thanked: 2139 times
Briggs,
Did you have luck using the JFET, or is it not worth it in view of performance?
ZJ
ZJ
