Tube2stomp wrote:
With such a LOW plate voltage there is not enough pull on the electron cloud.
When you connected the screen to the rail it could pull the electrons, because it is closer to the cloud then the plate.
This is kind of what is going on with low voltage car "space charge" tubes.
Your tube didn't go bye bye because with such a low voltage and not much current drive the screen *couldn't* kill it self.
Now that you have higher voltage, it would be wise to try and limit the screen so it won't go belly up... if it can.
And on a personal note:
Fish needs water
If you'll put a fish in a bowl with only half a glass of water
It won't be happy
You won't be happy
Tubes need high voltage
Give them high voltage
They'll glow happy
And you're guitar will sound healthy!
(sorry, I hate seeing tubes run on low voltage
Thanks for the comment....
Few things first....This particular tube was designed to run at max plate voltage of 60V as you can see from datasheet.
What I wanted to do is to make a clean booster that could fit nicely into A size enclosure...so if you have proposal how to stuck all that, and add supply which can produce near 60V from 9V wallwart that would be awesome...somehow I doubt that could be done even with all kind of voltage multipliers and if it is SMD made too...
Just to say I am satisfied how this thing sounds in this configuration (if we forget
that these particular types of pentodes are microphonic) this is really low cost, nice, clean booster.
I have few other ideas how to implement pentode in this kind of circuit, look
here but, later about that. Also I'm not the first and surely not the last to use this kind of tube in this manner. See
this.
I agree that tubes like more voltage but sometimes it's interesting to do stuff different.
Anyway, thanks for your opinion.
