70's Ibanez SG Bass LCR network.
- RnFR
So I opened up my 70's ibanez SG bass and was so surprised I had to post up a pic and ask if anyone knows what's up. I'm not a bass guy, but Ive not really seen this kind of set up before. Looks like a coil, a 4u7 cap, and a .22 cap. Anyone know WTF is goon on here? It's obviously an LCR network, but are there any other basses to compare to? Did the original gibbys have this too?
- DavidRavenMoon
The Gibson's did have the choke. The way that choke is made is very similar to the Bill lawrence designed choke used in the L9-S Ripper bass and the L6-S guitar. He actually used a bolt, a nut. and three washers, and then wound the two halves of the humbucking choke on it.
The purpose of the choke and the cap is to notch out the mids.
- RnFR
hey thanks! I never took the time to figure out which position did what. I usually just use it in the forward position, but I'm not sure if I ever even use the choke setting. have you seen a Gibson bass schematic?
- DavidRavenMoon
Gibson EB-3 schematic:RnFR wrote:hey thanks! I never took the time to figure out which position did what. I usually just use it in the forward position, but I'm not sure if I ever even use the choke setting. have you seen a Gibson bass schematic?
http://www.gibson.com/Files/schematics/EB3series2.PDF
Here's what the Ripper's choke looks like:
