4 hum-cancelling positions for 3 single coils
- earthtonesaudio
- Transistor Tuner
My goal was to get all 4 hum-cancelling combinations in a Strat copy, while remaining (importantly) very easy to use live. Here's what I came up with:
The four combinations are (left-right switch positions):
neck/mid series
neck/mid parallel
mid/bridge parallel
mid/bridge series
I'll probably make this with a rotary switch, because Futurlec has both 2P5T and 3P4T for $1 apiece. If I had lots of extra cash I'd rather use a blade switch but I can't find cheap ones with the requisite number of poles and throws.
...interestingly, you can swap the position of the ground and output terminals and it still works, but left-right is reversed.
neck/mid series
neck/mid parallel
mid/bridge parallel
mid/bridge series
- Cub
Looks very interesting, thank you for sharing ! I don't think I've ever heard the middle pickup in series with the bridge or the neck pickup on a Strat, does it still quack ?
- earthtonesaudio
- Transistor Tuner
Series connection does not really "quack" at least by my interpretation of the term.
I haven't done the mod yet so all I have to go by are the relatively few audio samples I could find online:
Best series/parallel audio sample, this one brought to my attention by someone on TGP:
http://www.harryj.net/strat_VV.htm (Scroll all the way to the bottom of the page under the heading "parallel, then series")
Best series/parallel demo I've found on Youtube:
Good description, mediocre audio:
Good presentation, but no direct comparison between series/parallel:
- earthtonesaudio
- Transistor Tuner
Yes, as long as it's a true DP4T.
I just found this thread which points out that a coil connected at only one end is an antenna. I should have remembered that! To avoid antenna-induced noise, I will alter my diagram so that the GND and output leads are swapped. That way the antennas will be transmitting their noise to ground, where it's not such a big deal.
- GuitarlCarl
- my favorite amplifier: anything tube
- Completed builds: Ds-1 mods, SD-1 mods, Small Clone mods, Muff build, Axis build, various other transistor booster builds... I can build a badaxe harmonic perc, but I can't get a fuzzface to sound worth a crap!
- Has thanked: 54 times
- Been thanked: 29 times
Is it in yer guitar yet? And How do ya like it?earthtonesaudio wrote: I haven't done the mod yet...
I've done a similar mod to a tele, and I DO like the series connection.
I want it to sound like bees buzzing around in a 55 gallon drum...
- earthtonesaudio
- Transistor Tuner
Haha, I'm nowhere near that stage yet. The guitar I have planned for this doesn't even have a neck yet... and I have been thinking of building that part myself, so the wiring is in the distant future.GuitarlCarl wrote: Is it in yer guitar yet?
Glad to hear you like the series connection on your Tele!
- timbo_93631
- my favorite amplifier: Low wattage SE amps
- Completed builds: Many many many true bypass and voicing mods on wahs.
A few BYOC kits and DS-1 mods and eventual murder then rebirth into an actually useful pedal, Bad Stone clone, various Rangemasters/SilconMasterBlaster, The worlds greatest gutted GCB-95 volume pedal conversion with various switching options for controlling amps. Repaired many tube amps, scratchbuilt Marshall 18 watt clone and Supro 1616t rebuild. Delays, fuzz, dirt, every Madbean project I could afford. I even manage to find time to make babies with my wife too! - Location: Fresno, Ca
- Has thanked: 14 times
- Been thanked: 33 times
I ditched the 3 pickup setup in my trusty 1999 MIM strat, middle pickup was never too useful for me. I have a fat strat pickguard loaded with GFS Mean 90's and a tele 3 way switch wired for neck, neck bridge parallel, bridge, but I also have a DPDT toggle that puts the neck and bridge in series. Bet of both worlds IMO, I have a less muddy more growl neck, chimey quacky parallel setting, ballsy bridge with fatter bottom and strong midgrange, and in series it is awesome for leads especially with a rangemaster.
"I wish to be in the situation of non killing my balls bills, and life surprises." -Sinner
"Everyone gets their shorts in a twist over who polished the fenders. No one cares about who designed the engine..." -DougH
- GuitarlCarl
Nice. I'm building a HSS tele right now, the controls are already wired using two stacked pots and a three way. Uses a blender for the middle pup, allows all three on at once, or neck and bridge... here's the schemo.
and the control plate wired...
- timbo_93631
That tele setup looks great! I forgot to mention that I have another DPDT for the tone cap with a sprague bumblebee 0.022uf on one side and a EROMAK 10nF on the other. switched to the 10nf I can get some cool gretschy tones with the bridge pu and tone control rolled back about 1/4 from max. I have found alot of veratility with the two tone caps. The switch is an on/on, in retrospect I wish I would have put in an on/off/on so I could have a "raw" setting that takes the tone cap out altogether, I can get the switch that is in there now to sit right in the middle sometimes and everything gets REALLY bright and punchy.
