Bass Wiring Help needed!!
Postby TechRockGroove » 04 Oct 2012, 08:01
Hello, I'm a newbie here.
I tried to rewire my bass to make it passive only using its Humbucker Pup with a B25k volume pot.
The humbacker has 4 colored wires (white, black, red, blue) and shield.
Here is what I did.
Red&Blue taped together, black and shield wires soldered to the Ground, white to #1 terminal of the Vol. pot
(I don't need the blend and coil split function).
Then from #2 terminal, the output wire is soldered to the Tip of the jack.
Also, 2 ground wires from the jack and bridge soldered together.
It doesn't work ....
could anyone teach me how to rewire
here is the schematic of my bass.
http://www.cortguitars.com/downloads/pdfs/GB75.pdf
TechRockGroove
Re: Bass Wiring Help needed!!
Postby roseblood11 » 04 Oct 2012, 08:47
First, find out which colors belong to which coil (and what is begiining or end...)
Then, use a 500k pot, a 25k will never work in a passive circuit.
For this message the author roseblood11 has received thanks:
TechRockGroove (04 Oct 2012, 12:51)
roseblood11
Has thanked: 348 times
Have thanks: 310 times
Postby TechRockGroove » 04 Oct 2012, 10:01
roseblood11 wrote:First, find out which colors belong to which coil (and what is begiining or end...)
Hello, roseblood11
thanks for the tip.
I figured out the Red&Blue wires are the output wires.
right now, there are 2 B100k and 1 B25k pots at home.
Can I go with a B100k instead of a 500k?
TechRockGroove
Postby lolbou » 04 Oct 2012, 11:02
TechRockGroove wrote:Can I go with a B100k instead of a 500k?
Say goodbye to your higher frequencies... Try 250k, that should be fine for a passive bass. 500k would bring up even more highs...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
For this message the author lolbou has received thanks:
lolbou
Has thanked: 350 times
Have thanks: 240 times
Postby TechRockGroove » 04 Oct 2012, 12:43
lolbou wrote:Say goodbye to your higher frequencies... Try 250k, that should be fine for a passive bass. 500k would bring up even more highs...
I see. I will buy a 500k then.
Thanks lolbou :D
TechRockGroove
Postby lolbou » 04 Oct 2012, 12:58
Oh, may I add : take a log pot, ie. A250k (or A500k if you really want it), not a B one. :wink:
lolbou
Postby CHEEZOR » 04 Oct 2012, 16:24
You should be able to use the 25k pot to wire everything up till you get the 500k. Just to make sure you have all the wiring right. Then when you get the 500k, you can just swap it for the 25k one, but at least you will have everything ironed out wiring-wise..
For this message the author CHEEZOR has received thanks:
dolganoff (26 Feb 2013, 13:35)
CHEEZOR
Has thanked: 71 times
Have thanks: 90 times
Postby dolganoff » 26 Feb 2013, 13:34
TechRockGroove wrote:Hello, I'm a newbie here.
Here is what I did.
You didn't say where goes the 3rd terminal of the volume pot? Drawing the schematics of your wiring and posting it here can help enormously in debugging :wink:
dolganoff
Postby bluescage » 27 Feb 2013, 10:56
Hi TechRockGroove,
I think it must look something like this:
Hope this helps
Ad
bluescage
