MIJ Fender Jaguar Bass preamp - schematic and PCB
Re: MIJ Fender Jaguar Bass preamp - schematic and PCB
Postby george giblet » 14 Oct 2017, 00:21
Re: Schematic and original PCB
I just check this and found a possible bug.
- I did forget to write down the transistor type :slap: :slap: ...
Some 2SCxxxx I can't remember.
[Still don't know. Top view (flat up): BCE]
- The zener diodes (D1 & D2) are BZX85C-5V1
- D3 is a silicon rectifier diode
- Baja: I traced one of these a couple of years back - pretty sure that the emitter resistor on the first transistor is 6k8 not 680 ohms.
[ Correct: Q1 and Q3 all emitter resistors are 6k8; as drawn.]
- Baja: Also the last transistor gain stage should have the 47p capacitor attached between base and ground not the second transistor buffer stage.
[ Incorrect: C10 definitely connects from Q2 base to ground.
The Sadowsky preamp has a cap like this.]
Wire Connections:
A = Treble cw (1)
B = Treble wiper (2)
C = D = Bass cw (1) & wiper (2) and Treble ccw (3)
; no wire actual goes to C, D used for both instead.
E = Bass ccw (3)
F = Emitter of Q3 (not used)
PCB:
C & D connects to C2
E connects to C3 and 18k
So there is something swapped regarding C2 and C3 on the schematic.
Is is the values, the designators or both?
- On the PCB C2 looks like C8, which is 47n.
- From the PCB, C2 connects to C & D (ie. to both bass and treble pots)
We conclude both the designator and values should be swapped
on the schematic. This agrees with the Fender tone stack
cap ratio.
george giblet
Has thanked: 29 times
Have thanks: 48 times
Previous
Users browsing this forum: Bside2234 and 9 guests
cron
