Jazzmaster mod - separate volume controls, strangle,...,how?
Postby Cortex » 02 Apr 2013, 11:50
Hi guys!
Recently I bought a Squier J Mascis Jazzmaster which I love but since I am not using the Rhythm circuit much, I am trying to find a way to do some mods to it, the ones that would include pretty much the functionalities depicted in this picture [yep, it's a Jag, but it doesn't matter] =>
I wondered if a similar thing could be done to the Jazzmaster? This is like perfection in my eyes. The jazzmaster would kill with these kind of options.
So, separate set of volume controls, and separate tone control set instead of the Rhythm circuit slider pots [probably I'm gonna need to swap them for 1M sliders right], and the Rhythm circuit switch should serve as some sort of series/parallel/strangle/bass cut/anything interesting/ switch.
So, any diagram depicting this mod but for the Jazz floating around? I can't seem to find it.
Thank you so much guys.
Cortex
Has thanked: 10 times
Re: Jazzmaster mod - separate volume controls, strangle,...,
Postby Cub » 17 Apr 2013, 15:46
You can use a Les Paul type wiring layout as an example, the only difference is that that the pots will be in a different place.
Put the strangle switch on the wire that runs from the pickup selector switch to the output jack and you're done.
Cub
Has thanked: 74 times
Have thanks: 87 times
Postby Cub » 18 Apr 2013, 06:38
Here you go, wire the pots like in the top drawing. Then include the switch as illustrated in the second drawing, just with a different pickup selector switch and straight to the output instead of a master volume pot.
Cub
Postby p.eat » 18 Apr 2013, 08:21
I'd recommend using the slider switch as a series switch!
p.eat
Has thanked: 52 times
Have thanks: 16 times
Postby trjones1 » 18 Apr 2013, 17:44
p.eat wrote:I'd recommend using the slider switch as a series switch!
Seconded! That's what I did on my Jazzmaster. The Jazzmaster pickups give the best "single coils in series" sound I've heard.
trjones1
Have thanks: 5 times
Postby Ben N » 18 Apr 2013, 22:01
Thirded. Having sported a Jag for a while, that strangle switch seems cool until you have to actually find a use for it. Well maybe with a bigger cap it might be a bit more useful, or possibly with an inductor based mid-cut, like a Bill Lawrence Q circuit.
Ben N
Have thanks: 9 times
