Buffer and treble bleed schem.
Could anyone help me with a schematic for a buffer and treble bleed in a guitar? I'm intrigued by the idea of having a buffer at the beginning of your chain (i.e. guitar) as suggested by R.G. I'd also like to experiment with a (very slight) treble bleed to ground - maybe only about as much as you would get just by having a tone pot since this guitar only has a volume knob.
- Silent Fly
I am also intrigued... by why people don't use Google.georgeb4 wrote:Could anyone help me with a schematic for a buffer and treble bleed in a guitar? I'm intrigued by the idea of having a buffer at the beginning of your chain (i.e. guitar) as suggested by R.G. I'd also like to experiment with a (very slight) treble bleed to ground - maybe only about as much as you would get just by having a tone pot since this guitar only has a volume knob.
If you run "treble bleed", the first link will give you everything you need to know - schematics included.
If you run "guitar buffer schematics", again the first link will explain how they work with an interesting series of schematics.
- TragicTravisty
after reading jack orman's article on low voltage dirtboxes, and learning that the voltage determines maximum headroom, and that the average peak of a guitar signal is 1v i wondered if a simple jfet buffer installed in a guitar would have any problem running on a single AAA battery (1.5v)? i understand that the voltage dividing resistors would need to be tweaked.
