RMC - Poly-Drive X
RMC - Poly-Drive X
Postby apollomusicservice » 27 May 2014, 09:22
A few days ago in my service popped in LGXT Godin guitar for repair.
The guys from the company RMC did not want to give me schematic for Poly Drive X preamp,
so I had to draw it. This is my drawing of the preamp for all those who need it as a reference or personal use.
More photos and information from my workshops on my Facebook page. https://www.facebook.com/pages/Apollo-M ... 5494552791
For this message the author apollomusicservice has received thanks: 16
bajaman (27 May 2014, 12:53), Fredenando (30 May 2014, 11:50), ggedamed (10 Oct 2015, 09:31), Intripped (27 May 2014, 13:25), IvIark (04 Jun 2014, 18:07), krome_magnon (31 May 2014, 17:16), lolbou (04 Jun 2014, 19:15), Manfred (10 Oct 2015, 21:23), modman (19 Oct 2015, 16:55), sinner (10 Oct 2015, 09:53) and 6 more users
apollomusicservice
Has thanked: 65 times
Have thanks: 773 times
Re: Poly-Drive X by RMC -schematic
Postby apollomusicservice » 30 May 2014, 10:21
more guts
For this message the author apollomusicservice has received thanks: 2
blackbunny (01 Jun 2014, 08:03), krome_magnon (31 May 2014, 17:16)
apollomusicservice
Postby patafix » 04 Jun 2014, 17:45
They made a revision in 2011. I ordered one. I can offer shots since I haven't installed it in my guitar yet.
There are a couple of mods from what I see, the most noticeable is the presence of two additional transistors and the swap of a tone cap from 33n to 47n...
Patafix... so sticky
patafix
Have thanks: 3 times
Postby n9voc » 10 Oct 2015, 04:31
Thank you so much for posting this. I needed to replace the battery connection - and your pictures helped assure me that it was going properly polarized! :applause:
n9voc
Postby Dirk_Hendrik » 13 Oct 2015, 18:01
Thanks fot the big job done! I'm still puzzled by IC1B though.
Has thanked: 255 times
Have thanks: 1021 times
Postby lolbou » 14 Oct 2015, 19:55
And where does U+ come from?
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lolbou
Has thanked: 351 times
Have thanks: 240 times
Postby Dirk_Hendrik » 15 Oct 2015, 15:29
One would expect U+ to be some kind of biasing voltage for the 6 FET's. For that reason it's rather odd to see that the opamp that seems to source this U+ is derived through an integrating opamp from the summing bus of those FET's.
I am sure more the brilliant minds see the logic of the setup straight away.
Postby coldcraft » 18 Oct 2015, 02:24
guys, its called a servo.
coldcraft
Has thanked: 42 times
Have thanks: 83 times
Postby Dirk_Hendrik » 18 Oct 2015, 16:37
Yes, a-DC servo. Continue on the why?
Postby coldcraft » 18 Oct 2015, 20:58
I doubt there's a strong reason why. probably just because they could.
coldcraft
Re: RMC - Poly-Drive X
Postby papasteack » 07 Feb 2018, 11:45
The individual input circuit/eq for each piezo is really interesting. If someone can simulate it, i would be very curious to see curves of the different individual input stages...
Graphtech piezo doesn't do this kind of induvidual tweak with their simple summing board.
papasteack
Have thanks: 2 times
