SC coil neck / HB Bridge with coil tap on HB
Postby sixxiron » 11 Apr 2015, 21:18
Newbie first post here and really looking to get the group's feedback. Here is what I am trying to do:
Single coil neck pickup with a humbucker bridge. A three way switch for the pickup selector and a single switch to tap the coil of the humbucker. Single volume pot with no tone pot. Any ideas/schematics on how to do this?
Thanks in advance!
Brad
sixxiron
Re: SC coil neck / HB Bridge with coil tap on HB
Postby Lucifer » 14 Apr 2015, 16:10
There are loads of diagrams available at a simple web search.
Here’s a site that offers loads of wiring possibilities - you should find something that suits you http://www.guitartechcraig.com/techwire/diagindx.htm
Good luck.
For this message the author Lucifer has received thanks:
sixxiron (15 Apr 2015, 16:55)
Lucifer
Has thanked: 104 times
Have thanks: 95 times
Postby sixxiron » 15 Apr 2015, 16:55
Thank you! I'll check it out
Lucifer wrote:There are loads of diagrams available at a simple web search.
Good luck.
sixxiron
Postby pietro_moog » 18 Apr 2015, 01:19
without tone control the guitar is gonna be super bright. and i would say that a splitted humbucker does not sound good
pietro_moog
Have thanks: 44 times
Postby Lucifer » 20 Apr 2015, 19:39
Following on from Pietro_Moog’s post, I could agree that SOME humbuckers might not sound too good when split (although I’ve always used quality pickups and never heard a bad-sounding split).
My preference is, rather than splitting the humbucker, to rewire the two coils in parallel rather than in series. This gives a brighter tone while still keeping the humbucking properties.
Once again, there are plenty of diagrams around the web for this, but you could try the Seymour Duncan site (SD normally includes such wiring diagrams with their pickups).
Hope this helps.
Lucifer
