separate pickup switches.
Postby deth502 » 13 Aug 2016, 01:45
heres my issue.
i rewired my strat. i have 3 humbuckers installed. a full size seymore duncan jb in the bridge, a sd jb jr in the middle single coil slot, and a sd hot rails (??) in the single slot neck position. i have each of them going into a 3-way switch to set them up for series, single coil, parallel operation, from there the signal goes to an on off switch for each pickup. the 3 wires from that then go to the vol/tone/output.
when i wired it up, it was dead silent. ( the cavities are covered in conductive paint) ..... a little too silent. i set the on/off switches to go to ground when they were off. this had the unforeseen side effect of grounding out the entire signal unless all 3 pu's were turned on (hence, there was no more path to ground)
of course, this was unacceptable. so i cut the gnd wires from the on/off switch and now everything works..... except.... when i have all 3 off (and the output is floating) there is a HORRIBLE buzz, and even when i turn one or 2 pu's on, the buzz is still noticeable.
any suggestions on how to ground these pickups to get rid of the hum without grounding the whole system rendering it useless?
deth502
Re: separate pickup switches.
Postby deltafred » 13 Aug 2016, 09:53
Welcome to FSB deth502.
What we really need is a schematic, internet fault diagnosis is usually no better the information given.
deltafred
Has thanked: 380 times
Have thanks: 259 times
Postby krome_magnon » 13 Aug 2016, 18:50
Try this, you will need 3 DPDT switches. When all of them are off the signal path is grounded and silent. If any one or more are ON then that pickup is connected to the signal path.
http://s725.photobucket.com/user/ruinbird/media/3puwdpdt_zpsfkktk9ig.jpg.html?sort=3&o=0
The noise from the tape deck was only drowned out by the buzz from the wine.
For this message the author krome_magnon has received thanks:
deth502 (14 Aug 2016, 16:03)
krome_magnon
Has thanked: 65 times
Have thanks: 18 times
Postby deth502 » 14 Aug 2016, 16:04
krome_magnon wrote:Try this, you will need 3 DPDT switches. When all of them are off the signal path is grounded and silent. If any one or more are ON then that pickup is connected to the signal path.
[ Image ]
AWESOME!! this is PERFECT! thank you!!!
For this message the author deth502 has received thanks:
krome_magnon (14 Aug 2016, 19:13)
deth502
Postby krome_magnon » 14 Aug 2016, 19:15
[ Image ]
The drawing stops at the neck + bridge combination for the sake of space. But all combinations of the 3 are possible.
krome_magnon
