Bigsby Condor prototype guitar 1967
Postby modman » 28 Feb 2017, 18:21
1967 Bigsby Condor Prototype Experimental Guitar, only 3 made, was to be called the Condor, one was given to Barney Kessel, the other was given to Howard Roberts, this one sat in Milwaukee since then, Paul Bigsby may have worked on this-no way to know, the pots are 1967, Paul died in 1968, Hammond was contacted for the electronics, and the work was contracted out to Gibbs Electronics in Milton Wisconsin, Natural finish, Rosewood fretboard, the guitar weighs 11 lbs. - 0.9 oz., biggest volute & headstock on Earth !!, huge neck profile, the guitar has been sitting for almost 50 years, it has not been tested, everything is in very good condition, don't miss this once in a lifetime chance to get an extremely cool & unique collectors item, has the original fancy heavy duty hard case.
https://reverb.com/item/2995374-bigsby- ... 67-natural
For this message the author modman has received thanks: 3
deltafred (01 Mar 2017, 19:07), Nocentelli (01 Mar 2017, 00:14), reddesert (05 Mar 2017, 23:55)
Has thanked: 3110 times
Have thanks: 559 times
Re: Bigsby Condor prototype guitar 1967
Postby reddesert » 02 Mar 2017, 08:16
It has a Centronics connector!!
For this message the author reddesert has received thanks:
deltafred (02 Mar 2017, 09:55)
reddesert
Have thanks: 12 times
